My DIY WTL Tonearm - Page 5 - diyAudio
Old 27th June 2013, 03:27 AM   #41
Sprags is offline Sprags  United States
I have nice balls for you to use for your next prototypes. And they are fast at computing to
Old 15th September 2013, 02:27 AM   #42
Very nice work. Do you make the oil tank and the ball hanger yourself? I can't imagine you can buy them off the shelves? If they are available off the shelve, I may try to make one using wood wand.
Old 12th October 2013, 06:16 PM   #43
Default Well Tempered Clone
Hello Everyone
Here are pictures of my latest version of the WT arm. I've been building these for over a year now and I have to say, it's the easiest arm in the world to get good results from. This one took around 2-3 hours to build!
How does it sound? Is it better than the others I have constructed? I'm getting to a stage now where there is a base line of excellent performance and each model I make sounds 'different' in one way or another-no better/no worse!
This one has a carbon fibre tube, filled with fine sand as the Bill F. one does. Next one will be using an arrow shaft. I've become a big fan of the arrow shaft after building a few of Nanook's arms. Thanks to Stew for this-Also I understand that you are contemplating building a WT clone, Stew. Have a go-couldn't be more simple.
Watch this space for more ideas and iterations
Chris G
Old 12th October 2013, 09:34 PM   #44
vinylkid58's Avatar
Nice work Chris. May I ask where you sourced the "well" that holds the damping fluid? I have one of Stew's arms here that I want to give the "WT" treatment.
jeff
Old 13th October 2013, 07:20 AM   #45
Default WT Arm
Hi
It's a stainless steel toothbrush holder cut down-just the right diameter for the golf ball-cost 1.96 from Asda (Wal-mart). Looks good too
Here's another photo
Old 14th October 2013, 05:55 AM   #46
vinylkid58's Avatar
Originally Posted by ChrisG139 View Post
Hi
Love it. You're right, it does look good.
jeff
Old 16th October 2013, 05:52 PM   #47
Default WT Arm
WT Arm 2 001.jpgWT Arm 2 002.jpgWT Arm 2 003.jpgHello Everyone
Here are more photos of my arm. I've been using it for a week now and can't fault it-it really is a superb performer.WT Arm 2 001.jpg
Old 25th October 2013, 04:07 PM   #48
Jay1234 is offline Jay1234  United Kingdom
Location: Way up North, In Newcastle haven't seen the Sun for days
Nice job Chris,
Are those two slotted brass screws holding the mono filament in place ?
Is the arm base a cam on a pivoting second base, to get the extra distance from, say a standard fixing hole ?
I have a ball, an arm tube, & a pillar. so gathering as much info as needed before starting my own WTA over the winter.
Jay
I'm wired differently to most
Old 25th October 2013, 09:06 PM   #49
Hi Jay
There is a single bolt under the base to mount the arm-it's off-centre to allow adjustment to be made. The fixtures for the monofilament are brass screws. Next stage is to use an aluminium arrow shaft instead of carbon fibre. I'm also going to experiment with fluids of different viscosity. Anyone out there know what WT Labs actually use? I'm convinced that this is a real improvement on all other arms I have tried or made.
This is one great arm!!
Old 25th October 2013, 11:17 PM   #50
bgruhn is offline bgruhn  United States
Hi Jay
Hi Chris,
It has been ~20 years since I built my WTA so the memory is a bit foggy, but I think it was 10,000 CS. The commercial WTA took about 9 to 10 seconds to descend from 1.5" maybe 2" to the record surface. Great fun to watch. I got 4 different samples from Dow Corning and tried them all. The one that duplicated that drop time was the one I used. Later I will look for the can, read the label and get back to you. If you have access to a real live WTA, golf ball type, try the drop test. The silicone fluid at 10,000 CS is thick stuff. My arm was a pretty close copy of the real, original model.
Rgds,
BillG
A DIY TONEARM - HELP PLEASE hallcon83 Analogue Source 15 28th June 2013 04:54 AM
QWTL and Half WTL in the same BIB cabinet tizio_82 Multi-Way 4 8th May 2008 03:49 AM
Another DIY Tonearm johnmarkp Analogue Source 0 21st April 2008 11:07 PM
my DIY Turntables and DIY tonearm Roger Waters Analogue Source 57 22nd January 2008 06:05 PM
Copyright 1999-2017 diyAudio
