Uher 4000 Report-L recording level problem
Old 2nd January 2013, 09:25 AM   #11
4ROB is offline 4ROB
Question Simple Checks
Just shot in the dark/Messure AC voltage Record Head,
Compare Bios Voltage,check with scop if have one.
if close/?boath changles or one/nex check Head wires to cicut board/dirrect or plug into Recorder-messure omes from input to out of plug/reason (system hum) This should take about one hour to check,
Good Luck 4ROB
Old 19th June 2013, 05:24 AM   #12
Are There any tubes in Recorder? if so check/
If not any plug in conector from Heads Clean contacts re insert any pre amp board with edge pull out and reisert old equtment contacs will oxidiz,
/de magnetize head's/clean vlume controls,
ANY diferance?
Good Luck 4ROB
Old 19th June 2013, 05:27 AM   #13
Default BIOS?CONNECTIONS?
Good Luck 4ROB
Uher 4000 Report-L recording level problemHide this!Advertise here!
Ah Njoe Tjoeb 4000 problem emperor Tubes / Valves 13 4th July 2016 07:36 AM
Uher 4000 Report-L Repairs Kaidanovsky Analogue Source 10 16th November 2011 11:56 PM
Recording, playbackís poor relation? Post a DIY recording. wakibaki The Lounge 4 2nd December 2010 04:46 AM
Help! - Akai GX-95 MkII, Bias, Recording level zstoja Analogue Source 0 25th June 2006 07:49 AM
recording problem with subwoofer Lťon The Pro Instruments and Amps 4 11th October 2005 08:18 PM
Copyright ©1999-2017 diyAudio
