New to vinyl; cartridge help
Old 22nd December 2012, 05:35 AM   #1
satx is offline satx  United States
Default New to vinyl; cartridge help
I recently bought a Marantz 6300 on CL. This is my first foray into vinyl so please assume I know less than nothing.
When I bought it it had a Shure m97xe on it, but the guy kept it. I could get another one, but I wanted to see if anyone would recommend something else.
My two channel system is a Peachtree Nova and Troels NOMEX 164 with the tweeter adjusted to -2.0db, so it's pretty smooth and laid back already. I'm undecided on the phono pre so let's assume an MM cartridge. Oh and my budget is $100 or less, less would be nice.
Thanks,
Evan
Old 22nd December 2012, 05:37 AM   #2
freax is offline freax
freax's Avatar
Ortofon OM Super cart and OM10 stylus, its what I use. And very cheap.
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 22nd December 2012, 05:39 AM   #3
By the way, some that I was considering are the Shure above, Grado black, Ortofon 2m red, and AT95e
Old 22nd December 2012, 05:42 AM   #4
Hey thanks, I'll check that out, does it lean towards one end of the spectrum, or pretty balanced? Also is it forgiving of less than perfect records?
Old 22nd December 2012, 05:44 AM   #5
Ortofon OM 10 Super Phono Cartridge
Is this it?
Old 22nd December 2012, 05:46 AM   #6
6L6 is offline 6L6  United States
6L6's Avatar
Honestly you can't go wrong with any of the above mentioned cartridges. My personal taste would rank them Ortofon, Audio-Technica, Shure, Grado, but that is just my preference. I'm sure that somebody would invert that order to suit their preferences.
Learn how to do a proper set-up and alignment. That's more important to sound quality than cartridge at that level.
Old 22nd December 2012, 05:47 AM   #7
freax's Avatar
Originally Posted by satx View Post
Thats it, and it looks great too.
I bought mine from http://www.turntableneedles.com/ tho.
http://www.turntableneedles.com/Orto...10_p_3938.html
Old 22nd December 2012, 05:49 AM   #8
Yes, that's on the agenda. I have read that the Shure is a little more fiddly to proper setup, that's why I was a little unsure if it was for me right now.
Old 22nd December 2012, 06:22 AM   #9
Ok so it sounds like there is nothing special I need to know. No special mounts or impedance or capacitance matching?
Old 22nd December 2012, 06:59 AM   #10
freax's Avatar
Nothing that the Marantz user manual won't tell you, aside from get a nice tube preamp.
You might want to replace the cable coming from the turntable with a lower capacitance one, thats up to you.
Replace the capacitors in the turntable.
New to vinyl; cartridge helpHide this!Advertise here!
Many different Vinyl Disc/LP Clamper-Vinyl Record Stabilizer/Clamper for Sound Impr. tiefbassuebertr Analogue Source 5 19th September 2016 11:03 AM
New " digital" vinyl vs old "analog" vinyl bullpeters Analogue Source 111 28th April 2013 09:35 PM
Vinyl wrapping - which vinyl? Frosteh Multi-Way 1 22nd August 2011 07:52 PM
suppo with vinyl? bonzo4ever Tubes / Valves 0 20th December 2009 08:28 PM
Back to Vinyl davidlzimmer Analogue Source 2 20th July 2006 11:11 AM
