New to vinyl; cartridge help
Old 23rd December 2012, 12:30 PM   #31
R.I.P.
Originally Posted by 6L6 View Post
It's pretty much impossible to make a good tube component for $100.
So no to Yaqin.
True, but its $240 new, probably pretty good for $90. Looks nice too ....
rgds, sreten.
Old 23rd December 2012, 04:37 PM   #32
satx is offline satx  United States
Yeah, I figured for $90, why not try it out. So I bought it plus it was free shipping. Plus, it's been tested and at least the guy said with his equipment there was no hum with 91 db speakers. The Cambridge was a safer bet, but I wanted to play around with some tubes since the only tube item I have is the buffer in the Peachtree and I leave that off most of the time. Anyways, thanks for the input.
Evan
Old 11th January 2013, 06:26 AM   #33
Default Thought I'd add an update:
So I got everything and finally got it working; I'm thrilled with the sound, though I was about to just give up and sell everything.
After I got the Yaqin and the Red Ed elliptical cart, I set everything up and began having tons of problems. At first I was only getting hum, but no sound out of the left channel, then intermittent sound. At the same time I was having a nightmare of a time aligning the cartridge, or so I thought. I downloaded the Stupid alignment protractor from Vinyl Engine, but I couldn't get it to print exactly to scale. I was getting tons of skipping and it was driving me nuts. Sometimes it was only skipping on the inside groves, sometimes one record would play through , but a different one wouldn't or even a different side wouldn't and sometimes the outer grooves would also skip. It didn't matter where I put the cart in the headshell and I had to have at least 3g's for it to even sometimes play.
Well, then the left channel went out for good. I traced backwards from the preamp and the tubes to the rca's and finally figured out that the left channel of the Red Ed was shorted and no longer functional. This was very frustrating as I bought a 40 year old turntable and a used preamp and the only new item in the chain is the defective piece. I contacted them and they immediately sent out a new cart and let me keep the old one; kudos to them for the service even if the QC may be a bit questionable.
So, new cart installed and still probably not aligned correctly and still having a terrible time with the skipping. Almost nothing would play. Well, after finally reading past the section in the manual about routine adjustments, I see mention of the cuing arm being adjustable. Sure enough, the arm that sits under the tonearm was just a bit too high and was not allowing enough pressure from the stylus on the record. I had listened to it before I bought it, so I'm not sure how it got out of adjustment. Now, after adjusting, it never skips and I can run it at 1.5g's with no problem.
This took a couple of weeks of screwing with it and I was about to give up; when it's this frustrating, music becomes pretty un-enjoyable.
Everything sounds very good now, though I still haven't been able to print the properly scaled protractor and I'm getting some sibilance on certain albums and I think this may be the culprit. Any help with this would be appreciated!
I'm now pleased with the Red Ed's sound and it tracks well, though I have nothing to compare it to.
The Yaqin is very nice and I feel like I got a very good deal. It is well made and sounds lovely and looks nice too. It even surprisingly came with Mullards installed. Pretty good for $90 shipped in my book. I was getting a little hum, especially when the Peachtree was in H/T bypass, but a cheater plug has removed that problem. I also had purchased a set of 5751 tubes to try in place of what I thought would be the stock Chinese 19ax7's and with their 30% reduction in gain any remaining hum has disappeared, plus I think they sound nicer than the Mullards.
Finally, the Marantz 6300 Seems to be a very nice table. It both looks and sound very good, it's 100% functional and I got it for a lot less locally than what they are selling for online.
Sorry for such a long post, but after all the help I got on here I thought I would let you guys know how it worked out. Also, someone may come along with the same problems as I had and be able to avoid some of the frustration
Evan
Old 12th January 2013, 10:49 PM   #34
kevinkr's Avatar
My experience with the Red Ed was not very positive on a diy table that I have long since given away. (Right channel died within minutes of first use, and it was pretty mediocre for the moments it did work.) Having had a taste of vinyl glory I'd recommend you go out and get an inexpensive Nagaoka, Music Hall, or Ortofon. (Not a DJ Ortophon though) Have a look at Needle Doctor's offerings.
Budget Phono Cartridges (no affiliation)
I guess I should ask what your vintage table is.. I have two Thorens TD-124 with modern Ortofon SPUs on them. (Schick and SME arms)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 14th January 2013, 04:22 AM   #35
The table is a Marantz 6300. I like the sound, but I need to get a good protractor to get it aligned right. It has a bit of sibilance sometimes and a bit of fuzziness to the sound, not always super clear. Not sure if it's the cart or alignment or what. In all honesty I don't see how it's much better, if at all, than good digital tracks. It's warm sounding, which is nice, but my system is pretty warm and smooth anyways. The digital stuff seems to have more energy, but retains the smooth sound. I may have to try a different cart, but I don't think I'll want to spend a lot on the vinyl gear; I'm just not seeing how it's worth it.
What budget cart from those brands do you recommend? I'd be willing to give it a go to see what they could do. I definitely want to get the one I have aligned right before I do anything though.
Evan
Old 14th January 2013, 04:36 PM   #36
kevinkr's Avatar
It strikes me that an Ortofon 2M Red would just fall within your budget range and should be a pretty big improvement. (Should be a good match for a low/low-medium mass arm)
http://www.needledoctor.com/Ortofon-...2&category=378 (No affiliation, but they are the Ortofon approved online vendor in the U.S.)
Old 15th January 2013, 03:32 AM   #37
Thanks, I was actually considering the Ortofon and it was recommended to me by Brian at Needle Doctor. I went with the Red Ed elliptical because it was cheap and it was my first foray into vinyl. Once I get everything set up correctly I'll probably take a shot on the Ortofon; a lot of people seem to be happy with it.
By the way isn't the tonearm on the Marantz a mid to mid-hi mass arm?
Evan
Old 1st July 2016, 05:31 PM   #38
mor2bz is offline mor2bz  United States
Thanks for the suggestion of the at95vl Sreten. I am enjoying much more than the shure 97e I had. It is bright but I was able to use my existing speakers. The bass seems light until it needs to be. I have a slight channel imbalance but do not blame the cartridge. I am using a bugle 2 w/ a cheap stepped attenuator built in into a straight power amp.
I don't care how the stylus attaches to the body but will get used to it.
very detailed, open, and transparent. enough gain and very little sibilance. just the way I like it.
Old 9th July 2016, 06:54 AM   #39
Nanook is offline Nanook  Canada
Nanook's Avatar
Default cartridge help (again....)
All:
almost everyone overlooks one of the obvious (to me) cartridges in the sub USD $100 price range: the Ortofon OM5 and OM10 cartridges. Way better than they should be. When set up correctly they have a fantastic sound. Not a "70's" throw back, but quite good and light on their feet. Any suggesting a Grado will know what I mean. (consider the Grado cartridges in the sub- $100 range too).
These recommends are assuming that your am and these carts would mate well...
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 9th July 2016, 12:58 PM   #40
6L6 is offline 6L6  United States
6L6's Avatar
I second that opinion - the inexpensive Ortofons are fantastic!
New to vinyl; cartridge helpHide this!Advertise here!
Many different Vinyl Disc/LP Clamper-Vinyl Record Stabilizer/Clamper for Sound Impr. tiefbassuebertr Analogue Source 5 19th September 2016 10:03 AM
New " digital" vinyl vs old "analog" vinyl bullpeters Analogue Source 111 28th April 2013 08:35 PM
Vinyl wrapping - which vinyl? Frosteh Multi-Way 1 22nd August 2011 06:52 PM
suppo with vinyl? bonzo4ever Tubes / Valves 0 20th December 2009 07:28 PM
Back to Vinyl davidlzimmer Analogue Source 2 20th July 2006 10:11 AM
Copyright ©1999-2017 diyAudio
