Garrard 60 MkII good or not?
Old 20th December 2012, 08:47 PM   #1
sco1t is offline sco1t  United Kingdom
sco1t's Avatar
Smile Garrard 60 MkII good or not?
Hi people, just wondered if a Garrard 60 MkII is a good record player or not? It has a Shure M97x cartridge...
Old 20th December 2012, 08:56 PM   #2
R.I.P.
It really depends on what your quality expectations are and its condition.
As an autostacker, some would use for singles, others for 78's.
Its really not suitable for your main turntable, lots of other better options.
rgds, sreten.
Old 20th December 2012, 09:02 PM   #3
sco1t's Avatar
Hi Sreten,
it's still like new.
so it would be better to get a better player for high quality?
Thanks for the reply
Old 20th December 2012, 09:13 PM   #4
R.I.P.
Again its all relative. Cheap AV system with a phono input and cheap
records from charity shop why not ? Decent records and a decent
system its not really up to the job IMO, but it will be OK.
Its much better for a hifi fan as a 78 player, and if its in great
condition even more so for that purpose for an audiophile.
Its probably not that bad, but in very good condition its
worth a lot more to the particular than the average man.
rgds, sreten.
Old 20th December 2012, 09:34 PM   #5
sco1t's Avatar
ok thanks for the Advice
Old 20th December 2012, 11:02 PM   #6
Nanook is offline Nanook  Canada
Nanook's Avatar
Default try gutting it
A Lab 60 (I'm assuming that's what you have) is quite nice once you remove all of the changer/stacker hardware. Get rid of the tonearm as well. Something similar to try is the old Dual 10XX or 12XX series (again gutted).
Once all the mechanical stuff is removed, the major source for poor sound is removed (springs, excessive mechanical bits, etc.).
I've converted a few of the Duals and they are very good once stripped. I'm working on a Lab 60 as proof of concept and have a Lab 80 that will get converted once I get a feel for what is going on with the '80.
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 21st December 2012, 12:45 AM   #7
sco1t's Avatar
Hi, should I upload a song from it to see if people think it sounds good or rubbish? lol
It seems to distort when singers hit a really high note :S unless that's just how records are? that distortion is also a little more from the right speaker then the left..
I've adjusted the tracking to 2 grams seems to be best.
Old 21st December 2012, 02:19 AM   #8
indianajo is offline indianajo  United States
indianajo's Avatar
Definitely salvage the M97 cartridge. I have one, era IV, love it, and probably have played thousands of sides with it over the 33 years I've owned it. No surface damage @ 1.5 g.
I noticed as a kid in 1966, the Gerrards the city library had, rumbled. I don't know what model. My best friend had a Gerrard he bought in 1968, it rumbled. He gave it to me, still does. I bought a 1961 build AR turntable in 1970 with my tube amp. It didn't rumble, but bounced on the record when I walked across the floor. Nor did it shut itself off or lift the tonearm. I put a Grado FTE cartridge on it in 1972? it sounded pretty good at 1.5 g. I'm now using a $69 BIC 940 changer I got on closeout about 1979, with the M97. It doesn't rumble or have any bad habits except I had to put a washer under one side of the cartridge to get it square to the record. The BIC has a changer and auto shutoff, no problem. I sold off my AR turntable in 1981, and never looked back. So much for legends.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 21st December 2012, 06:53 PM   #9
Nanook's Avatar
Default distort on right chassel...""SSsssss...."
A couple of things:
  • as indianajoe points out Garrardsrumble (well most idlers do...)
  • suspended decks often don't isolate well from foorfalls
  • using a shim of some sort can help with azimuth of a carttridge
If your records are in good shape there should be no sibilance. Is the stylus clean? The records? Look at the idler wheel, take it off of its spindle, clean it and relube the bushing, then re-install.
The only way to reduce the rumble AFAIK, is to remove as much mechanical stuff as possible. The Shure M97x or a variant is still available and new stylus should still be available for yours. Also consider a better constructed plinth.
Old 21st December 2012, 07:08 PM   #10
R.I.P.
If it is in "as new" condition stripping it is a bad idea, somebody
will want it in original condition. The rumble (if it does) is due
to the main bearing arrangement around the centre spindle.
Less of a problem with mono records and mono wired cartridge.
Sibilance may mean the stylus is worn out, or defective,
or not properly aligned, incorrect tracking force or bias etc.
rgds, sreten.
Garrard 60 MkII good or not?Hide this!Advertise here!
WTB: 120VCT (60-0-60) transformer for balanced power supply jmillerdoc Swap Meet 2 14th April 2011 06:08 PM
Yamaha M-60 power amp for sale (w/ impaired C-60 preamp) rainzoneman Swap Meet 10 3rd December 2009 01:44 PM
Service Manual Request: Marantz CD75 MkII or CD65 MkII jeff mai Digital Source 9 23rd April 2009 04:48 PM
Garrard 401 60 Hz pulley wpod Analogue Source 5 27th February 2008 11:32 PM
Garrard 60 MKII, Phono cart, preamp??? blumenco Analogue Source 1 14th May 2006 03:56 AM
Copyright ©1999-2017 diyAudio
