Voltage Conversion of Jolida JD9
Old 15th December 2012, 02:57 PM   #1
Mohan Siribadda is offline Mohan Siribadda  Sri Lanka
Smile Voltage Conversion of Jolida JD9
Hi Diyers,
Can anyone advise me how to carryout voltage conversion from 110 V 60HZ to 220V 50Hhz on my recently acquired Jolida JD9 from USA.
I have written to Jolida and they are yer to respond to my request.
One of the vendors said that in order to get this converted to local voltage of 220V 50HZ, I have to locate the slider switch which is located at the back of the phono amp. The slider has to be shifted to the position correspond to 220V 50HZ and at the same time the fuse has to be changed to suit 220V and the appropriate current rating.
Kindly advise me, if someone knows simple modification of this JD9
Look forward to hearing from you soon.
Best reards
Mohan
Voltage Conversion of Jolida JD9Hide this!Advertise here!
Jolida JD9 Upgrade/Mods Clarification. nathanjh13 Analog Line Level 41 12th August 2015 12:30 AM
New black Jolida JD9 w pics. midfi Analog Line Level 0 23rd October 2011 01:34 AM
Jolida JD9 Problem jkasch Tubes / Valves 4 16th May 2011 11:00 PM
Better Sounding Direct Replacement For OPA OP37 In Jolida JD9 Phono Stage XTRprof Analogue Source 5 30th June 2007 10:00 AM
voltage conversion mike moore Everything Else 4 10th February 2001 07:43 AM
