Armageddon clone for LP12 - why such a large transformer?
Old 7th January 2013, 10:16 PM   #41
sharpi31 is offline sharpi31  United Kingdom
I've had my geddon-esque psu running constantly for a few days, but still not listened to it. I was getting 95Vac to the motor given the 140Vac coming from the transformer and 4K series resistance. I have read that the linn motor is quietest with a 65Vac supply, so now increased the series R to 10K which has brought me down to almost exactly 65Vac.
The weird thing is that I was measuring a lower Vac after the 0.2uF cap with the higher voltage supply (about 85Vac vs 95Vac) but now that I've increased the series resistor to 10K I'm reading a higher Vac after the cap than before it (71.5Vac vs 65Vac). With about 6K series resistance I was getting similar voltages on the two phases.
Is this because my meter is rubbish, or is this as it should be? If the meter is accurate do you think I'd be better with the 6K series R and balanced voltages on the two phases, or 10K series R with unbalanced but lower voltages?
The deck struggles to start with 10K series R but doesn't need a helping hand - it gets there on its own :-)
Old 13th April 2014, 11:54 AM   #42
Mikewong is offline Mikewong  Italy
Could I use resistors to cut down the supply voltage to 85VAC If I got a transformer with 120 Volts AC output for this cloned project?
I have one toroid at 725VA with 3x0-40volts AC secodaries out.
Old 26th April 2014, 08:00 PM   #43
Pyramid is offline Pyramid  United States
Pyramid's Avatar
Default TD150 motor supply
Take a look at this regenerative PSU: Digital PSU and Tach
DDS circuitry provides low distortion, extremely accurate (35µHz steps) sine wave. Front panel selectable voltage reduction after platter reaches speed, soft start ramps the frequency to reduce "burn out" on the belt.
Can be used stand-alone or with the digital tach for quartz locked accuracy with a belt drive.
Old 30th April 2014, 07:38 AM   #44
davidsrsb is offline davidsrsb  Malaysia
Having a higher voltage after the capacitor is normal, you have a resonant LC circuit with the motor inductance.
I prefer to have the two windings at the same voltage as any difference causes vibration
Armageddon clone for LP12 - why such a large transformer?Hide this!Advertise here!
Using “Almost-right” toroid for Armageddon Clone truepaul Analogue Source 14 15th August 2012 01:34 AM
Using a large 60hz toroid transformer as an SMPS transformer EWorkshop1708 Power Supplies 20 22nd June 2011 08:05 PM
Large one to one transformer available tjencks Swap Meet 0 7th April 2011 09:45 AM
Kove Armageddon 15" 1050rms gadgeteer123 Swap Meet 1 25th December 2009 04:09 PM
Transformer: How large? sangram Solid State 22 15th January 2003 04:58 PM
Copyright ©1999-2017 diyAudio
