diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Analogue Source (http://www.diyaudio.com/forums/analogue-source/)
-   -   B & O TX Tunrtalbe help needed. (http://www.diyaudio.com/forums/analogue-source/225191-tx-tunrtalbe-help.html)
mv55 7th December 2012 02:24 PM
My Tx turntable is acting up. The arm lowers on the record and starts to play but the carriage does not move and the arm slowly creeps towards the other photo arm while the other arm is stationary. I have the repair manual. Any help would be greatly appreciated.
TANDBERGEREN 7th December 2012 07:11 PM
I believe there is a rubber band that drives the arm-carriage.
You should check that one first.
Also the mechanism on the carriage that "grips" on the threaded rod that this little rubber band drives.
Not easy to guide You wthout any pictures or videos.
mv55 7th December 2012 07:29 PM
The little belt that drives the carriage and is attached to the threaded rod is fine. The arm will self power to the record and can be cued all the way to the end and back. The issue is that when it is cued on the record and starts to play the carriage does not move in unison with the arm and stays stationary. I suspect it is a photo sensor issue but not sure what to look for.
TANDBERGEREN 7th December 2012 07:51 PM
You may be correct there sir.
I could look in t the schematics and see what I find.
Could You please telle what type-number there is on that turntable?
Should be on a sticker on the rear, 4 digit type number.
mv55 7th December 2012 08:03 PM
Thanks Tandbergeren. It is labeled Type 5653. I have a No.1 and 2 cartridge and it would be a shame to scrap it.
pfcs49 9th December 2012 08:24 PM
where's your location?
I'm in NW NJ and have a functional TX parts unit if you're willing to pick it up.
Glad to see it live on.
phil
mv55 9th December 2012 09:00 PM
Thanks Phil. I sent you a PM.
Resources saved on this page: MySQL 18.75%
