diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Analogue Source (http://www.diyaudio.com/forums/analogue-source/)
-   -   Electrolyt as DC blocking (http://www.diyaudio.com/forums/analogue-source/224759-electrolyt-dc-blocking.html)
Erlend Sæterdal 1st December 2012 07:56 PM
Hi anybody know how many dc volt elektrolyts can block ?
jcx 1st December 2012 08:16 PM
use bipolar - with full rated V for both directions - higher V in excess of needs reduces measureable distortion
yagoolar 1st December 2012 08:37 PM
Or make a bipolar of two electrolytics. Connect "-"'s one to the other. Take into account capacity is halved and each cap must be rated max DC you block.
PS. However, sonically not the best idea.
Erlend Sæterdal 1st December 2012 10:01 PM
My I/V stage has + 10 V out. I know it is + so normal electrolyt must be ok if I use + as in ? However they let around 4 v pass though.
Impedance after them is 47 kohm.
Erlend Sæterdal 1st December 2012 10:27 PM
Just discovered bipolar blocks. There is 2 on each output. There is + on one and - on the other so the one on - has to be reversed.
yagoolar 2nd December 2012 09:34 AM
You don't want elcaps on i/v out. Use good film caps MKS/MKC or MKP. From wima or roederstein/vishay
Erlend Sæterdal 2nd December 2012 10:09 AM
I do not like filmcaps. I think electrolyts is better when there is no place for DCA cast. Have you ever tried electrolyts where there is a few volts on them ? Eletrolyts off best quality offcourse.
yagoolar 2nd December 2012 01:25 PM
Yes, I have tried and compared film to electrolitycs. Replaced elcaps or bipolars with styroflex or polycarbon in a couple of CDs, amps (SS & VT). The difference is huge across the whole spectrum of music.
See here also: The "Sound" of Capacitors
yagoolar 2nd December 2012 01:33 PM
or High End Audio - Electrolytic capacitors
more on picking caps from Walter Jung
http://waltjung.org/PDFs/Picking_Capacitors_1.pdf
http://waltjung.org/PDFs/Picking_Capacitors_2.pdf
TANDBERGEREN 2nd December 2012 02:00 PM
Originally Posted by yagoolar (http://www.diyaudio.com/forums/showthread.php?p=3267016#post3267016)
Nice, but Why is there no "curves" for electrolytics?
Copyright ©1999-2017 diyAudio
