MC and MM Resistor and Capacitor Loading - Page 4 - diyAudio
Old 3rd December 2012, 02:07 PM   #31
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Received the DL-110 early. Sounds good for the most part but on some passages where high frequency has a lot of energy, I get distortion. Adjusting VTA and over hang helped a little. When adjusting, the distortion moved from the left channel to the right channel and high freq distortion became a bit less evident. Not sure what the problem is, but I still need to try to install the provided cart plate for added weight. I just hope the cart is not defective.
I might also be using the wrong loading, which is what this thread is all about anyway!
Using the 150 ohms used by the 103R. The 110 requires 47k. I tried my old phono pre that has a MM 47k settting, but still had distortion.
The high output cart did not help the over all gain of my system (still have to crank the preamp volume past 2 o'clock), however there is a great deal more bass, and is as enjoyable as my CD player without the glare of digital.
I build, therefore I am.
Old 3rd December 2012, 09:42 PM   #32
The Space Egg Corp's Avatar
Hi Vince
I think a lot of people like about 1K with the Denon DL-110...
...despite what manufacturer says.
Should sort the problem... me tinks.
Cheers
Si.
'Sweet Spot' in your system, could be a bit either side of this, of course.
But def. WAY lower than 47K.
Old 3rd December 2012, 09:49 PM   #33
Hi again Vince
I would try using a 5K pot. maybe just on 1 channel.
ZER0-in on the optimum sound.
Remove the pot.
Measure it.
Replace with a fixed resistor ( wire-wound, OF COURSE ! )
You may just hit a 'Sweet Spot' value of...
...eg. 1001.99 Ohms ( or something ! )
Cheers.
Si.
Old 3rd December 2012, 10:26 PM   #34
bgruhn is offline bgruhn  United States
About wire wound resistors: They come in two varieties, non-inductively wound, and ordinary inductively wound. Is there any problem with whatever inductance the resistor may have so that it would be desirable to specify non-inductive ones? This is mostly to satisfy my own curiosity on the subject?
BillG
Originally Posted by The Space Egg Corp View Post
Hi again Vince
Remove the pot.
Measure it.
Cheers.
Si.
Old 4th December 2012, 03:08 AM   #35
Hi Bill
Morgan Jones, in his exellent book 'Valve Amplifiers'...
...says the inductance of even low value WW resistors "is trivial".
A low-value 220R one, only had 0.2deg. phase shift from 100Hz to 100KHz.
All others tested, showed "no 'measurable' deviation" of phase.
A 1.2K one, had ( depending on example measured ) between 6 & 18uH...
...an 'Ayrton-Perry wound' 1.2K had 9uH inductance.
I was slightly concerned about this, but it seems there is no real-world issue, unless they are for RF amplifiers, of MHz etc. ranges.
Wanting to build a preamp ENTIRELY with wire-wounds, I feel safe to do so.
I don't have a 'Henry meter', & probably won't bother to get one either...
...although they are cheap enough & it MIGHT be interesting !!! Mmmm.
Morgan Jones quotes the NOISE of a metal-film resistor, as 0.1uV/V dropped across them...
...I think the build-up of resistor-noise, particularly in hi-gain low-level amps, such as phono's & mic-pre's could be quite significant; microphones ( which I sometimes make ) also.
I'm surprised people aren't using them.
OK...bit more expensive maybe...
...seems like the real reason might be, they aren't easy to 'stuff' PCB's with; p2p or custom boards only.
WW's FOREVER !!!
BOO JAH !!!
Cheers.
Si.
Old 4th December 2012, 03:14 AM   #36
Just to put the 6 to 18uH inductance of a 'typical' Denon DL-110 load resistor of 1.2K in perspective...
...The Denon DL-110 cartridge has an inbuilt inductance itself of 380uH.
It's 160 Ohms ( I think ).
Cheers.
Si.
Old 4th December 2012, 10:19 AM   #37
DF96 is offline DF96  England
Yes, audio designers are peculiarly frightened of WW resistor inductance - or even spiral-cut metal film inductance. In some places it matters, but often it does not.
Old 4th December 2012, 01:25 PM   #38
vdi_nenna's Avatar
Might have to get this Morgan Jones book.
Old 4th December 2012, 07:54 PM   #39
Hi DF96
I can't help wondering if WW's are rejected in comercial designs ( for obvious reasons ( NOT inductance ! )...
...and this 'filters down the chain', even to the DIY builder.
As Nelson Pass says about 'super-hot' class-A amps...
...not EASY for a manufacturer to readily ( & affordably ) deal with the size & heat issues.
For the DIYer, he says, this is entirely do-able.
Not that many 'audiophool' WW's available either...
...perhaps due to 'inductance paranoia' !
The 'audiophool' resistor market, seems to have mostly been cornered, by products offering :-
Old-school, Carbon-composite.
Non-magnetic construction.
Exotic materials ( still metal-film though ).
Precision products ( 0.1 - 0.01% even ).
The HUMUGOUSLY expensive industrial 'bulk-foils'...
...seem the only option, offering a potential 'noise-reduction'.
Hi Vince.
Morgan Jones's book is well worth getting, just for general concepts.
TEN PAGES, just on the subject of resistors alone !
Very readable.
Exellent diagrams, tables etc.
Probably, actualy proof-read the old-school way ( ie. accurately ! ).
If you never even pick up a valve, or even consider using them...
...the book is still a gold-mine of universal audio wisdom...
...with decent 'real world' explanations of the technical stuff.
How's the Denon sounding ?
Have a look around the Net to check what people are saying about loading.
1K ( ish ) some go for 2K ( ish ) as well, I think...
...does seem 'low' compared to Denon's recs., but seems people are liking this area.
Some are putting the 'load resistor' in plugs etc...
...so probably still have the 'standard' 47K resistor in their pre-amps still in place & in parallel with the 1K etc. they load with.
More sound reports on the DL-110 please Vince !!!
Cheers.
Si.
Old 5th December 2012, 01:41 PM   #40
Most even good RIAAs have a rolloff so this cap is unnecessary to mount.
There is also some capacitanse in the cable all the way from the cartrigde and to the connectors to the amp, wich often is more than sufficient to make the correct HF-rolloff.
Sooner or later you end up with TANDBERG
MM cartridge capacitance loading stevomaso Analog Line Level 17 10th February 2012 08:18 AM
MC v MM Cartridges Rosinante Analogue Source 3 19th November 2010 08:07 PM
Mm Or Mc hal1 Analogue Source 5 9th August 2007 02:51 PM
MM Cartridge loading question gurevise Analogue Source 7 16th December 2003 12:30 PM
MM or MC how to tell which one I have Rino odorico Analogue Source 5 22nd September 2002 01:39 PM
Copyright 1999-2017 diyAudio
