Old 28th November 2012, 12:17 AM   #11
andyr is offline andyr  Australia
Originally Posted by AMV8 View Post
Hi
If you add a second phono socket in parallel to the input phono socket you can add the loading by inserting a loaded plug into the second socket. The main advantage of this method is that you can accomodate most any cartridge and also "fine tune" to get the result you are after.
Don
Agree, Don - that's the way I do it. In fact, for a MM phono stage, I would suggest 2 parallel pairs of RCAs ... so you can adjust 'C' as well as 'R' load.
The issue with using switches at such low signal levels is that they always degrade the SQ, compared to if the switches weren't there.
Andy
Old 28th November 2012, 01:13 AM   #12
The Space Egg Corp's Avatar
Why would a switch in parallel with the cart...
...de-grade sound-quality...
...any more than a plug & socket ?
Neither are 'hard-wired'...
...so what's the difference ?
Just part of the load resistance, surely ?...
...about 0.002 milli Ohms, for most 'decent' switches.
Si.
Old 28th November 2012, 01:21 AM   #13
In actual fact...
...a plug & socket is 'in theory'...
TWICE as bad.
As it has 2 contacts...
...as opposed to a switch...
...which can have just 1.
Si.
Old 28th November 2012, 01:26 AM   #14
Let me give you a couple of examples:
1. I modified a phono stage which I had bought from a local dealer (who designed it); I added a simple switch to connect the R & L signals together, to make it mono. (It's nice to be able to have mono when you're setting up your system, sometimes.) This switch substantially degraded the sound stage, compared to before ... so I removed it!
2. This same dealer has a Doge 8 preamp (which he loves). The Doge 8 comes with a switch for MM/MC - Mike told me that the MM circuit sounded substantially better after he had disabled the switch (he has the top Grado MM, the 4mV Reference Reference1, so he doesn't use the MC section).
Andy
Old 28th November 2012, 01:41 AM   #15
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Space Egg, I'm receiving the DL-110 on Dec 3rd. Do you like it? I have a heavily modded 103R now.
One site described using a large 1 meg + resistor in parallel always and figure for other parallel values.
Using a DIP switch one can call up many values with less resistors.
Phono Cartridge Loading
I think adjusting the load is a bit different than using a tone control.
I build, therefore I am.
Old 28th November 2012, 01:41 AM   #16
Talking Saw this on the wonderfull WWW...
Of course with any scheme using 'fixed-values'...
...you may just miss 'the sweet-spot' by a country-mile !!!
Saw this on the WWW somewhere.
Simples !
The guy made 2 precision 'calibrated pots'...dialed in the values...
BOOM !
Job done !
Can always replace the pots with a fixed value if you're worried about them.
BINGO ! 'sweet-spot' found for ANY cartridge.
Smart dude...
...lateral-thinking !
Si.
Old 28th November 2012, 01:56 AM   #17
Hi Vince
You might be able to tell me if YOU like it first...
...cos I don't have one yet !
My friend is importing 2 from the USA for us both.
( considerably cheaper, than in 'rip-off Britain' ! )
Anyhow...
...seems like just about every living / hearing being on the planet since it was born in 1982 !...
...recs. it's A WINNER !
Very FLAT...
...what more could you ask for ?
Mega-detail...
...& way less surface-noise reproduced.
None of this 'rising-response' tosh...
...like some 'audiophile' carts either.
The Japs know how to listen...
...& they like things FLAT !!!!!
Cheers.
Si.
wot u think of the pot box ?
Old 28th November 2012, 02:06 AM   #18
vdi_nenna's Avatar
Great price for such good reviews. Think they were used in broadcasting in Japan.
The box is very cool. Always wanted one but for crossover design. They exist.
Old 28th November 2012, 02:10 AM   #19
Hey Vince
Did you build a Zen 9 ?
That's the Nelson amp with the resistor bias, right ?
Love to know what you think, if you did...
...looks FAB to me.
Si.
Old 28th November 2012, 02:21 AM   #20
vdi_nenna's Avatar
Yes, built the zen 9. Very nice amp. Its uses the aleph CCS, with special attention to load line, from what I understand. Zen 8 uses resistor load, I think. Very nice amp but the 2sk82 CCS SIT amp edges it out. The detail from the SIT is amazing, but its only 5w. The zen 9 beats the SIT in pure force only. Building the choke SIT next at 10-12 w output.
MM cartridge capacitance loading stevomaso Analog Line Level 17 10th February 2012 08:18 AM
MC v MM Cartridges Rosinante Analogue Source 3 19th November 2010 08:07 PM
Mm Or Mc hal1 Analogue Source 5 9th August 2007 02:51 PM
MM Cartridge loading question gurevise Analogue Source 7 16th December 2003 12:30 PM
MM or MC how to tell which one I have Rino odorico Analogue Source 5 22nd September 2002 01:39 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
