| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Tiny piece of female Velcro tape behind the needle some where up the angle of the cart at a place where it barely contacts the vinyl when needle is in play. Tested with tracking disc. Does *not* significanty alter track force until fully loaded . Loops do not damage records. Ideal
#2 |
A pic will welcome.
#3 |
Camerally challenged.
#4 |
I feel this is important enough to get a pic on here somehiw, and will ASAP. For what it is worth, the geometry of this stupid little trick makes it work far better than a brush in front of the needle (regarding non interference with tracking force) This is one of those things you with you could patent, but doing so would make a decent person feel silly. I have found no, zero , zilch issues with this whereas the Shure V15 kind of brush is no more effective and has a variable mass. If you position this correctly and keep it clean it has a lot less effect on the needle due to the fact that it is located in behind the stylus. Not to get silly here but the obvious analogy is " where do I sit the fat kid in on the tweeter totter" If you sit him closer to the fulcrom,he can be fatter and not screw disrupt the CG. Stupid
| DIY carbon fiber brush | marekst | Analogue Source | 2 | 19th February 2008 04:17 PM |
| Brush Soundmirror early tape recorder? | jacques54 | Analogue Source | 1 | 13th January 2008 08:06 PM |
| diy record cleaning brush - it works!! | federico moreno | Analogue Source | 0 | 7th September 2005 04:47 PM |
| Cheap PE Line Array speakers, now 49 cents! | OilStain | Multi-Way | 2 | 21st August 2004 02:12 AM |
| Turnable mat and record brush | roy1xord | Analogue Source | 2 | 29th February 2004 01:04 AM |
