Want to build a tiny battery powered RIAA
Old 18th November 2012, 09:46 AM   #11
Killingbeans is offline Killingbeans  Denmark
Originally Posted by jackinnj View Post
You might want to DC couple the input (eliminate the 220uF electrolytic) and place a blocking cap (10uF) on the output -- this will save space and improve the performance at the low end.
But the amp is DC coupled (both input and output)?
You can make the amplifier a little less noisy by reducing the resistor values by a factor of 6, increasing the capacitor values by 6. -- and if you use 5.8 you'll get the exact values in Jung's "Op Amp Handbook"
Too late. I've already bought most of the caps
Old 6th October 2013, 03:21 AM   #12
tabarddn is offline tabarddn  New Zealand
Default Just in case
Just in case your Phono amp does not work out. I am using a tiny amp from a guy called davidyee. Sound is fantastic and super quite, will run off 9 v - 12 v.
With my battery operated TemaadAudio turntable I am in audio heaven
tabarddn
Want to build a tiny battery powered RIAAHide this!Advertise here!
Want to build Unusual high powered battery powered headphone amp (and equalizer) bakalorz Headphone Systems 5 10th September 2012 03:17 AM
new Battery powered TK2050 Amps! 2 right now, I might build more later. gripracer Swap Meet 18 31st January 2011 08:15 PM
Trying to build a small battery powered amp... James39 Solid State 5 30th October 2009 06:30 AM
Newbie wants to build a "GainClone-Like" 5.1 Channel Battery Powered Amplifier captain Chip Amps 7 15th October 2004 12:35 PM
battery powered RIAA preamp question Mad_K Analogue Source 8 27th October 2002 10:10 AM
Copyright ©1999-2017 diyAudio
