Old 26th November 2012, 12:15 AM   #31
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Is it worth the step up from the DL 110 to the 103, ...I'm also a bit concerned about the very low output of the 103 ...
Old 26th November 2012, 12:42 AM   #32
vinylkid58's Avatar
IMHO, bypass the 103 and go for the 103R "if" you have a heavy-ish arm, or you have the ability to add mass to your existing arm. You may need a SUT, like the CineMag 3340's.
jeff
Old 26th November 2012, 01:21 AM   #33
scott wurcer's Avatar
We discussed adding tone arm weights somewhere in the BT thread (good luck). I think the lead tape they sell to tweak golf clubs would work here.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 26th November 2012, 02:44 PM   #34
expert in tautology
bear's Avatar
Well now, these "upgrades" where they "replace" the cantilever, is it not true that what is really going on is that *everything* except for the case and the magnetic motor assembly is being replaced? Nothing remains of the old coils, damper ring, cantilever and tip, and that piano wire suspension thingie??
I'm not saying that this is a bad thing, just that there's really little resemblance between the old and new.
Too bad there is no way to just replace the cantilever alone...
_-_-bear
PS. speaking of which, one USA rebuilder <name withheld> whose rebuilds friends have acquired when measured all seem to have a freq response peak above 10Khz. The peak appears to have a slope of about 12dB/oct going up. This means that it is unlikely that a simple capacitive loading will yield a flat response. Most users of this rebuilders work are unaware of this (apparently) and few users are sophisticated enough to even know about capacitive loading of phono cartridges as an option, or to have done it, or have the preamp with this available.
something to think about...
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Old 26th November 2012, 02:56 PM   #35
I'm confused, I thought it was an MC cart with a LOT less L and R to work against the C???
Old 26th November 2012, 04:40 PM   #36
expert in tautology
bear's Avatar
scott-tay,
the HF rise is/was unambiguous.
I presumed some sort of resonance...
_-_-bear
PS. also present in the "new" offerings from the same vendor (fyi).
_-_-bear
Old 26th November 2012, 04:49 PM   #37
a.wayne's Avatar
103r vs goldring , any comments .....
Old 26th November 2012, 05:27 PM   #38
kevinkr's Avatar
<snip>
_-_-bear
The ones I have seen all had the original generator assembly, damper ring, etc. - the only thing replaced was the cantilever and stylus which is generally glued into the the end of the old one which is cut somewhere near the mounting bushing.
FWIW as a long time user of LOMC cartridges including SPU and DL-103 one tames the HF resonance by varying the loading R, capacitance is generally ineffective. A number of people I know use rebuilt DL-103 loaded into a couple of hundred ohms and have not observed unusually large resonances in the pass band. (They have the hardware and motivation to make measurements)
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 26th November 2012, 06:23 PM   #39
scott-tay,
_-_-bear
I meant cap loading won't help in this case as in MM. Not exactly the same mechanisms at work here.
Old 26th November 2012, 06:27 PM   #40
Any input on the spherical stylus vs other profiles? The articles mentioned were fairly compelling, naming several majors that used the predistortion. I myself have not been able to measure any difference using various test records including ones that put the test signals directly into the lathe recording electronics.
Denon Dl-103 resonance frequency northernsky Analogue Source 4 12th October 2011 05:31 PM
whats best step up for denon DL-103 vinylflo Analogue Source 7 27th September 2011 04:22 PM
Head Pre for Denon DL 103 gpapag Analogue Source 86 20th December 2009 10:08 AM
WTB broken Denon Dl 103 IZHAKKATZ Swap Meet 2 9th January 2009 07:12 AM
help- retiping denon dl 103 IZHAKKATZ Analogue Source 20 20th November 2008 03:20 PM
Copyright ©1999-2013 diyAudio
