Mounting rca jack
Mounting rca jack
Old 11th November 2012, 06:20 PM   #1
wanders is offline wanders  United States
Default Mounting rca jack
I'm relocating a set of female rca jacks on an old turntable. The jacks will mount to a piece of aluminum stock. In looking at the jacks I see that the barrel of the jack is one size, but one of the two plastic shims has the same interior diameter as the jack barrel, but also has a slightly larger collar that could fit into a larger hole in the aluminum, thereby insulating the barrel from the panel. I assume then, that the hole in the panel should be larger than the barrel, the same size as the extrusion, to insulate the jack from the aluminum panel? Am I thinking right?
Old 11th November 2012, 06:33 PM   #2
Mooly's Avatar
Mounting rca jack
That's right, the plastic washer with the collar locates in the hole in the panel to totally insulate the socket.
Mounting rca jackHide this!Advertise here!
RCA Jack for Wallin Preamp Randallm Parts 0 3rd October 2011 03:49 PM
Rca jack question mike49504 Car Audio 7 21st August 2010 08:28 PM
RCA Jack Design NEAR_SOTA Parts 0 23rd August 2003 06:38 AM
RCA Jack Bulk Purchase? roddyama Parts 81 27th March 2003 01:04 AM
