problem with a vynil record
Old 2nd November 2012, 11:27 PM   #1
andreidaniel is offline andreidaniel  Romania
andreidaniel's Avatar
Default problem with a vynil record
Hello everybody! I have a problem with a vynil record: long time ago my father use on it an anti-static spray..and when I want to listen it, the vynil has a noise.. How can I solve the problem?
Thank you!
Old 3rd November 2012, 12:40 PM   #2
fastbike1 is offline fastbike1  United States
Try cleaning it. There is almost always "noise" with vinyl. Lots of information on cleaning techniques on Google. You can start with simple deionized water and lint free cloth.
Thank you!
I was so much older then, I'm younger than that now.
Old 3rd November 2012, 08:24 PM   #3
YNWOAN is offline YNWOAN  United Kingdom
YNWOAN's Avatar
Your father cleaned the record with a product called Permostat that was supposed to reduce static (as you say, it was a spray). This product is well known, over time, to dry out in the record grooves and cause a lot of noise. The answer is to use a record cleaning machine to wet clean your records - this will remove the Permostat.
Old 10th November 2012, 07:50 AM   #4
MLStrand56 is offline MLStrand56
Default Re: Wet Cleaning
My favorite manual wet cleaner is the "Discwasher". To clean the Permostat, us the wet side of the brush longer than normal. Then slowly rotate the brush to dry the record.
MLStrand56
problem with a vynil recordHide this!Advertise here!
record arm slides to end of record!? gongli Analogue Source 4 26th August 2009 02:36 PM
zenith mlt 15 console record player problem tim614 Tubes / Valves 14 6th July 2008 03:33 AM
1/3 oactave stereo pink noise on VYNIL 30bandgeek Car Audio 0 22nd November 2006 12:05 AM
TEAC x-2000r record mode stuck. Record light flashes but won't play. Any ideas? mistered05 Analogue Source 1 30th June 2005 12:51 PM
birch vynil veneer sorce needed mightyjimbo Multi-Way 1 28th March 2004 07:20 AM
Copyright ©1999-2017 diyAudio
