Bouncy floor tweak for suspended tables
Old 31st October 2012, 01:43 PM   #1
limono is offline limono  United States
Default Bouncy floor tweak for suspended tables
I found it on some audio forums and it supposedly originated from LINN . To eliminate (or mostly eliminate) problems with footalls on the floor rack simply drill the rack's top shelf and mount two 2"x2" (or something similar) pieces of lumber cut to lenght between the rack and the wall. The wood should rest tight on the wall. It did wonders to my Linn table (on loan) and should work with any close to wall setup with TT.
Old 31st October 2012, 02:16 PM   #2
DF96 is offline DF96  England
Even better: don't use a rack, mount a sturdy shelf straight on the wall.
Old 31st October 2012, 02:42 PM   #3
bear is offline bear
expert in tautology
bear's Avatar
depends a bit on the wall and how it is connected to the floor, and where that is... like in the middle of a wood frame building, it might move quite a bit...
... there are other options, but they tend to cost more than a shelf screwed to the studs...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 31st October 2012, 04:01 PM   #4
All true , but sometimes you don't have the stud where you want it , you have a stand and no money on wall shelf ,etc
Bouncy floor tweak for suspended tablesHide this!Advertise here!
Need opinions on Turn Tables.... Big_Bill Analogue Source 19 18th September 2009 11:02 PM
Augspurger's alignment tables Dave Jones Multi-Way 22 14th April 2007 10:13 PM
"BOUNCY" momentary startcircuit TomWaits Solid State 9 9th September 2006 01:55 AM
please help with MJK's alignment tables just a guy Subwoofers 61 11th August 2006 06:40 PM
HOw close does driver need to be to floor to avoid floor bounce? Kanga Multi-Way 8 24th April 2003 06:09 AM
