FM Stereo indicator lamp in Tuner circuit
Old 26th October 2012, 08:25 AM   #21
djmeverett is offline djmeverett  United States
djmeverett's Avatar
Thanks Mooly...good to hear my calculator and formulas were right!
I think I'm going to try the lamps and if they all light up....I'll call it good.
This Roberts receiver is not a high end machine by any stretch and I've been very thrifty in it's repair. But it sounds great now and this was the last thing to fix before I button it back up and I think it will be fine for another few years.
Just another unit saved from the dumpster....
It was a nice simple unit to work on for me and I didn't have to spend much, learned a lot and had fun doing it!
The lamp analysis was the icing on the cake!...and I thank all for their comments and patience.
Old 26th October 2012, 08:32 AM   #22
sofaspud is offline sofaspud  United States
sofaspud's Avatar
A breadboard experiment may be the best way to go. A look at flicker fusion threshold supports both our positions. I didn't know it could get so complicated... a real eye-opener.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 26th October 2012, 09:09 AM   #23
Mooly's Avatar
Originally Posted by djmeverett View Post
Thanks Mooly...good to hear my calculator and formulas were right!.....
Your welcome
And its great to work on purely discrete circuitry too. There are always ways and means and options available, something that isn't so when its stuffed full of IC's and the like.
A lot read there. I did a quick test before seeing all that and this is what I got. A red LED fed via a sinewave source.
Direct viewing straight at it and I consistently got 41hz as the point I would be unaware it was AC fed.
Edge of field (corner of the eye) and it was around 52hz
Head moving from slow to quick. That took the 52hz up to around 2Khz.
Moving the LED quickly. That pushed the upper limit to easily 7Khz. If I could have soldered wires to the LED rather than holding it all together (so I could move it even faster) then that figure would be higher still.
So there we have it
FM Stereo indicator lamp in Tuner circuitHide this!Advertise here!
I am looking at the tuner circuit FISHER FM-2421 Dmitry Ukraine Everything Else 2 5th June 2012 03:26 PM
Bang and Olufsen 609k stereo se el84 fm tuner brianbrian Tubes / Valves 4 29th May 2012 09:44 PM
Fisher FM-50 tube tuner and Dynaco FM-3 tube tuner hatrack71 Swap Meet 5 25th January 2011 11:43 PM
Larsholt fm tuner front end for JLH tuner design-Any still available? djsb Analogue Source 0 25th December 2008 05:46 PM
FM Stereo Tuner Tube Schematic ? calico88 Tubes / Valves 5 21st June 2006 03:49 AM
