diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Analogue Source (http://www.diyaudio.com/forums/analogue-source/)
-   -   The A.N.T. Audio Kora 3T Phono Stage circuit published. (http://www.diyaudio.com/forums/analogue-source/221720-n-t-audio-kora-3t-phono-stage-circuit-published.html)
x-pro 17th October 2012 01:57 PM
As I've recently stopped production of the "Special Edition" version of the Kora 3T phono stage (the "Limited Edition" version is still available), I've uploaded a short history of its development and full circuit diagrams for both MM and MC versions at the "Special Edition" level. The Limited Edition MC version was awarded the "Phono stage of the year" title by Hi-Fi World magazine in 2009 and it is still the phono stage to beat, in my opinion. I will be happy to answer possible questions here.
Enjoy!
Alex
Stefanoo 17th October 2012 02:04 PM
Thank you very much for sharing it.
It looks like a very nice design. I will post more later.
Anyhow, please, also follow the thread MasterPiece and give a contribute to it if you feel like it :) ...
I know...I know....this is subliminal commercial.... what can I do?! :) :)
Thanks again for sharing!
x-pro 17th October 2012 06:47 PM
Thank you! I've read a bit of your thread and found that you've said:
Originally Posted by Stefanoo (Post 3204282)
I have noticed that it is very hard to design an MC stage with enough gain with relative simple circuit (except for paradise) or at least with the different circuits we explored so far I am sure there are better ways out there I simply don't know them.
FYI, the MC version of the Kora 3T has gain 62dB at 1kHz - enough for all but the lowest output cartridges and referred to the input noise is about 100nV RMS (A-wtd). Not bad at all for such a simple circuit.
Cheers
Alex
Stefanoo 17th October 2012 07:04 PM
Cheers
Alex
Yep I agree with you. I think it is a nice relative simple design.
However I meant to say to get enough gain with just one gainstage (actually two stages input and VAS) and get 62dB using only Jfets.
But eather way I am folding back to the two stage design as well.
Again thank you for sharing your design.
x-pro 18th October 2012 07:45 PM
Here are some measurement results for the Kora 3T MM SE - the frequency response using precision (<0.1% error) reverse RIAA and the distortion spectrum for 1kHz 1V RMS output. Both graphs are typical for production units.
Cheers
Alex
http://www.ant-audio.co.uk/Theory/Kora3TMMSE_FR.gif
http://www.ant-audio.co.uk/Theory/Ko...kHz_1V_THD.gif
fap 19th October 2012 07:59 AM
G'day all, I'm glad to see this thread and it's quite timely too as hopefully I will take ownership of an ANT Kora 3T phono stage shortly.
I've been building some simple FET audio circuitry of late and they do sound 'nice'. Maybe it's 'euphonic' distortion perhaps but it is a joy to listen to! Regards, Felix.
x-pro 20th October 2012 01:15 AM
Hi Felix,
Apparently the parcel is already in Brisbane!
Cheers
Alex
fap 20th October 2012 01:34 AM
G'day mate, that's good to hear, alas within this country the postal services can be a mite slow especially getting up here in the north of Queensland!
I am really looking to comparing it against my beloved DIY ESP P06 phono stage which I regard as truly 'reference' quality.
If the ANT Kora 3T is better than the P06, that will be extremely impressive indeed! Regards, Felix.
Salas 20th October 2012 03:01 AM
Hi Alex, nice simple elegant circuits as always. Why the BAV clamp bridge? Protecting the SIPMOS device's gate for hot plugging input abuse, or something different? I have some BSS135 for low dissipation position in HV cascode CCS use but never got to see about its intrinsic noise, what is the nVsqrtHz for its BSS139 bro? Mosfets are not famous for low noise, but some DMOS can be nice exceptions? Reminded me I am overdue for those BS170 switchers I got to test for audio use because I liked their 320mS gfs and 24pF Ciss. Enhancement mode though, they won't self bias.
x-pro 20th October 2012 02:25 PM
The diodes are for protection. I have no returns of faulty production units for 4 years of production.
The noise of the BSS139 according to my estimate is about 15-20nV/sqrtHz @ 1kHz or about the same as for the TL072 opamp. The A-wtd noise of the Kora 3T MM SE with 1kOhm source impedance is about -81dbA for 1V RMS output, as it has ~39dB gain at 1kHz it would be ~1uV A-wtd RMS referred to the input. The LE version has about a half of that noise but even for the SE as described the noise is never an issue in real life.
Cheers
Alex
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
