Old 22nd October 2012, 01:36 AM   #21
fap is offline fap  Australia
G'day all, yes I agree with Alex. I tend to only trust a properly soldered connection.
Twenty five odd years of being a Ham Radio operator and a former telecommunications maintenance technician has taught me that! Regards, Felix (vk4fuq).
Old 22nd October 2012, 01:41 AM   #22
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by x-pro View Post
Here is a noise floor comparison between the Kora 3T MM SE and MM LE units I've done some while ago.
That 10dB improvement reflects the upper part of the SRPP contribution we should suppose? Because the lower part owes to be dominated by the K170 en?
Old 22nd October 2012, 01:44 AM   #23
Salas's Avatar
P.S. No, you wrote its the MM. So its due to the Mosfet parts change only.
Old 22nd October 2012, 02:00 AM   #24
x-pro is offline x-pro  United Kingdom
x-pro's Avatar
The noise graph is for 2 MM units, so there is no 2SK170 involved there. The noise difference is only due to the two different types of FETs in M1 and M2 positions. As I've said earlier, the BSS139 has a noise voltage density about 15-20nV/sqrtHz at 1kHz, the "LE" type FET has less than half of that, about 6-7nV/sqrtHz at 1kHz. In the MC version the noise contribution of the input 2SK170 is dominating, however there is still some difference in the noise between the SE MC and the LE MC units, about 1.5-2dBA.
Yes, I was late with my answer, sorry!
Cheers
Alex
Old 22nd October 2012, 09:22 AM   #25
UV101 is offline UV101  England
UV101's Avatar
I was looking for a phono stage to build and this could be it.
Would you consider allowing pcb's to be made for a group buy on the forum?
Also, is it just the quality of component choice that is changed for the better versions?
Thanks for sharing, Ian
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
JA-88D Class A, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 22nd October 2012, 10:15 AM   #26
andyr is offline andyr  Australia
Sure Felix, I agree that's optimal. But it means you can't readily change cartridges. Which (facility) is a good thing to have. Just like not having coupling caps is "optimal" ... but not that many components go this way.
I have no doubt it will be better than your ESP phono stage ... but, once you've got your Kora up and running (with the soldered resistor of your choice installed ), I could send up my JFET phono stage for you to compare. (You have my email address.)
Enjoy.
Andy
Old 22nd October 2012, 11:11 AM   #27
x-pro's Avatar
Hi Ian,
I am not sure that I should authorise a group buy of an untested pcb. On one hand the Kora 3T circuit is so simple that it can be built on a strip-board in one evening, on another hand I may offer the original pcb (or even a kit) for DIY. The pcb would fit one of the Hammond aluminium enclosures perfectly and would at least guarantee that the performance of the circuit won't suffer from a bad layout. It won't be very cheap thought .
On the second question - I've described the differences in the post #18.
Cheers
Alex
Old 22nd October 2012, 01:14 PM   #28
UV101's Avatar
Hi Alex, thanks ;-)
If you we're considering offering some sort of kit or even just the pcb, I would definitely be interested ;-)
Old 22nd October 2012, 01:25 PM   #29
x-pro's Avatar
Hi Alex, thanks ;-)
PM me.
Cheers
Alex
Old 22nd October 2012, 02:53 PM   #30
UV101's Avatar
Pm sent, Thanks, Ian
help with phono stage circuit design lightmaster Solid State 3 3rd October 2012 06:54 PM
restore the circuit phono stage vog Analogue Source 0 8th November 2010 05:47 PM
Steve Bench's LR Phono Stage - Cathode Bias Circuit Question Hearinspace Tubes / Valves 3 19th October 2009 04:26 AM
Borbely Audio phono stage biovizier Swap Meet 12 9th February 2007 07:09 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
