Old 12th October 2012, 05:19 PM   #1
Cool Stylus issues...
Hello everyone,
I'm new here, been using the forums for quick answers on my turntable related issues for about a year now, and you guys are great!!
I've built a custom turntable from a Rega RP1 body, using an Ortofon 2M Blue cartridge ( not my favorite ).
I have an issue, and I was wondering if you all could help me;
I've aligned my cartridge/Cantilever without a shim, and on the protractor it looks great, however when I'm playing a record I'm noticing about 3/4 of the way in the cantilever is moving so close to the cartridge body ( like the record is pulling the needle toward the center ) that it's nearly bumping the side wall. Because of this, I'm hearing some slight distortion.
I was wondering if anyone else has had this issue before, and if it's something I can fix! I have a moderate understanding of alignment, but I'm no professional. I have an RB-100 on there, no VTA, and I prefer a slightly lower than 1.8g tracking weight.
if anyone could make some suggestions, have some thoughts on this, I'd be more than happy. Thanks!!
Old 12th October 2012, 05:25 PM   #2
SY's Avatar
Check your antiskate adjustment?
If there's a sucker born every minute, where do the rest of them come from?
Old 12th October 2012, 06:16 PM   #3
I've just checked it, it's set at .5 ( rega scale 0-2 ) I've noticed when i set this to 0 ( factory suggested ) even clean records skip.
Thanks SY
Old 12th October 2012, 07:02 PM   #4
indianajo's Avatar
Is your table level? Mine is not, and turntable orientation affects the anti-skate setting required.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 12th October 2012, 07:43 PM   #5
SY's Avatar
If the lack of antiskate causes skipping, you have a fundamental problem. Could be leveling, as ij suggests. Could also be pivot problems in your arm.
Old 12th October 2012, 09:00 PM   #6
It's so close to being perfectly level, I installed a spirit-level in the 2 critical points on the turntable. I like where your heads at though..
Now pivot could be the culprit, could installing my tonearm slightly off (1-3mm) of the factory pre-drilled tonearm 3-point holes have anything to do with it? I'm pretty sure I'm not that far off but man is it hard to align a tone-arm on a new non-factory DIY plinth..
Old 12th October 2012, 10:42 PM   #7
Hi, check the arms lateral friction for stiction, rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 12th October 2012, 10:57 PM   #8
AVWERK is offline AVWERK  United States
Is the compliance of the cartridge a match for the tonearm in mass?
Don,t assume all levels are accurate. Turn it around end for end (180 degrees) the bubble should be same in both directions if its good.
Pull the mat and place it on the platter if its a non suspended TT
On the tracking force issue, find some piano records and notice if you still have distorted notes on the louder transients. Some notes have very fast rise times that make the needle go crunch if not enough downforce is applied. If you can,t get it to track there, its time for a new cartridge.
David
Old 12th October 2012, 11:00 PM   #9
SY's Avatar
Put on the stylus guard, then set the tracking force to zero so the arm "floats." See if a puff of breath causes the arm to freely pivot to the inside.
Old 12th October 2012, 11:19 PM   #10
Thats a good one SY.
We used to do a similiar test with the Grace 707 by zeroing out too balance and placing a corner of a dollar bill, just the 1 # placed on top of the headshell.
If it didn,t move, the bearings needed ajustment.
A 1/4 of a gram or something like that' can't remember.
Now many hours does a stylus last? johnmarkp Analogue Source 21 2nd October 2008 06:36 PM
Stylus run in time?? emperor Analogue Source 15 13th April 2007 07:43 PM
year old stylus Bama Slamma Analogue Source 1 20th March 2007 02:56 PM
the right stylus/cartridge solonbro Analogue Source 38 2nd April 2005 09:24 PM
Advice on ortofon Stylus' Shoog Analogue Source 21 24th January 2004 09:27 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
