help me find an FM 1/4 ground plane or 1/2 dipole diy antenna plan for broadcast?? - Page 3 - diyAudio
Old 28th November 2012, 12:37 AM   #21
DUG is offline DUG  Canada
Was the USB device designed to feed a 50 or 75 ohm load?
If it is then great...get a cheap dipole FM receive antenna and hook it up.
If it was not then attaching something to the transmitter stage will load it differently.
The output stage was designed to resonate with the L and C and equivalent R of the board it was built on. Nothing more nothing less.
RF transmitter stages are not like an audio amp.
RF load impedance can be affected significantly by loading and can either lose significant signal or load the output device to the point of destruction.
Not recommended but play anyway...hope the thing was not expensive.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
star ground vs. ground plane Sebastiaan Chip Amps 93 13th February 2017 11:41 PM
DIY FM antenna, can it be better than radioshack junk? homer09 Everything Else 86 7th October 2013 07:00 PM
Ground plane or star ground? yakideo Chip Amps 6 27th March 2011 05:06 PM
DIY FM Antenna DreadPirate Everything Else 9 26th March 2011 03:06 AM
FM broadcast gear redrabbit Analog Line Level 1 8th June 2007 10:49 AM
Copyright 1999-2017 diyAudio
