Turntable playing thorough one channel.
Old 4th October 2012, 11:04 AM   #11
sofaspud is offline sofaspud  United States
sofaspud's Avatar
I don't unfortunately. AFAIK, there isn't anything particularly special about it; just small and flexible. Soldering any break you find may be fairly easy.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 4th October 2012, 11:24 AM   #12
RRSS is offline RRSS  United Kingdom
Cool. We'll I'll have a more thorough look tonight. If I can't find the culprit I might just give in and take it to my local audio shop.
Thanks for your help.
Old 5th October 2012, 07:19 AM   #13
I can't find any obvious lose connections.
I rang my local audio shop yesterday; they said it would be something fairly simple, which is a bit annoying...
I have ordered a new phono cable and phono plugs to mount into the base of the turntable, instead of the 'old fashioned' way of having an un-connectable phono cable permanently attached. This will be my last attempt I reckon, if this doesn't help I will just bite the bullet and take it to the shop.
Old 10th October 2012, 04:24 PM   #14
78RPMcollector is offline 78RPMcollector  United States
I had that problem with a Technics SL1200MK2. It turned out that I just needed to remove the headshell and clean the four contacts inside the bayonet mount. They are spring loaded. I used a cotton swab with isopropyl alcohol. Problem gone.
Old 12th October 2012, 09:20 AM   #15
Ah really? I'll give that a go, cheers.
Old 17th October 2012, 02:03 PM   #16
The other day it started playing both channels... I have no idea why. Not complaining, although I'd like to know what was causing it...
Old 17th October 2012, 02:28 PM   #17
just an idea is offline just an idea
really it can only be a fault in the cable or the cartridge. as they are the only sound developing parts on the turntable.
Last night I had the same problem, just as I'd taking my TT round to friends house to show it off and it only played in one channel... after knocking the wire descovered there must be an internal break in one of the chanel lines, with the right position I still have contact. Don't give up!
Old 17th October 2012, 04:14 PM   #18
RRSS, I'd have to agree with just an idea. If it's not dirty contacts in the bayonet, it can only be the wiring, probably a tiny break that sometimes connects. Check the four tiny wires on the cartridge for continuity or simply replace them. Next, see if wiggling the cable does anything or wiggling the phono plugs. Worst case is the cartridge.
Turntable playing thorough one channel.Hide this!Advertise here!
Now playing… martyh Analogue Source 2 27th June 2008 02:46 PM
Correct gain drop when playing one channel on two speakers halfgaar Everything Else 6 12th November 2006 06:53 AM
what's better, a mid playing high, or a tweet playing low??? cody6766 Multi-Way 10 20th February 2005 09:40 PM
put my pre-amp together and now the left channel is playing distorted :( elizard Solid State 21 4th April 2003 06:23 AM
Copyright ©1999-2017 diyAudio
