Masterpiece
Masterpiece
Old 23rd May 2013, 07:13 PM   #981
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Thanks guys, I want to use it with Salas Itch tube phono MM togheter my Denon DL103R tuned so I will need bal/in unbal/out as the schematic and pics. I need to change the 1K input resistor?
Old 23rd May 2013, 07:17 PM   #982
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
You can. Do you want to go higher or lower ?
Lower is not a problem at all.
Higher then 5kOhm is not advisable with this circuit though.
This is because the "natural" input impedance of this circuit is not very high.
If you need more then 5kOhm you can try BC327-40, BC337-40.
I would then reduce the current in each transistor to under 5mA.
Old 23rd May 2013, 07:18 PM   #983
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
yes, you will need 200ohm per side to maximaze interface with your Denon.
Stefano
Old 23rd May 2013, 07:22 PM   #984
Grazie mille Stefano / thank you Joachim
Felipe
Old 23rd May 2013, 07:22 PM   #985
Stefanoo's Avatar
Grazie mille / thank you
Felipe
Prego!
Stefano
Old 23rd May 2013, 07:30 PM   #986
Do you know if I have to buy a big quantity to match the transistors or with 20 or 30 pcs of each I will have enough?
Old 23rd May 2013, 07:39 PM   #987
They are cheep and because thy are made since many years they do not go astray much.
I even could send you some. When i knock on heavens door do you let me in because i am such a good guy ?
Old 23rd May 2013, 07:48 PM   #988
Thanks Joachim, I accept your offer, YHPM. I don't know if I can open the heavens door but for sure I can open my house door for you.
Old 23rd May 2013, 08:17 PM   #989
Heaven is a place on earth....
Old 23rd May 2013, 08:23 PM   #990
King Crimson - Fallen Angel (Live 1972 RARE) - YouTube
MasterpieceHide this!Advertise here!
Lyra Connoisseur 4-2L SE: What a masterpiece! Sigurd Ruschkow Solid State 58 27th January 2015 08:16 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 08:37 PM
