Masterpiece - Page 88 - diyAudio
Old 5th May 2013, 04:52 PM   #871
MiiB is offline MiiB  Denmark
I agree that current inputs can sound a bit dry, and they do need some "input" impedance.. the rolloff is strongly circuit dependant.. the circuit I play with now changes 0,2 dB at 20KHz with different cartridges.
Anyway, its just fun to play with these circuits.. funny how many ways you can get good sound out of the grooves.
Old 5th May 2013, 06:07 PM   #872
Joachim Gerhard's Avatar
Sure, now that my Atlas, my Olympos and my Titan are gone to the HighEnd in Munich i am back to my modified MC 30 Super. I also gave Martina my Stille Phonostage so i am back to my tube transimpedance phono stage. I thought why not using my LA Audio mono blocks then so the first time i have a complete tube system. Sounds great too.
Old 5th May 2013, 06:10 PM   #873
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Will try the new mundorfs... do not know f I can get the "special" micas but IMO micas are ok for the 500.5Hz but too much sparkling for the highs were I use mostly small styrenes as "fill in" bypass.
Used to like the shinkoh for cart rload but now found the new vishay bulk metal to give even better results.
For the 500.5Hz resistor I really like the kiwame carbons.
Thank you for the tip: PF1262-5KF1 Riedon | PF1262-5000-ND | DigiKey
What resistor type are these ?
RC
Old 5th May 2013, 07:35 PM   #874
Thin film, they also make metal foil like Vishey but then we are talking about 13,- € a pop.
I have good contact to Jahre and they can make silver micas in small quantity to order.
They even make a boutique version.
Old 5th May 2013, 07:38 PM   #875
look at the golden one :
Richard Jahre GmbH: Bauform 43.19
Old 6th May 2013, 12:02 AM   #876
Stefanoo's Avatar
Originally Posted by RCruz View Post
32.1nF and 11nF
Are these caps tin foil types ?
There are the best custom Teflon cap on the market available due to my group buy....I don't understand why going to fuss around with other stuff when you can have the best!
Sometimes I don't understand!!!
Stefano
Old 6th May 2013, 07:16 AM   #877
nhinstruments
RCruz's Avatar
Those teflon caps are way too expensive for me Stefano
RC
Old 6th May 2013, 09:03 AM   #878
Reliable RTE Capacitors
I did not try them but John Curl said that they are the next best thing to teflon caps.
Old 6th May 2013, 09:04 AM   #879
Old 6th May 2013, 12:06 PM   #880
nhinstruments
RCruz's Avatar
Those are my prefered caps.
RC
Lyra Connoisseur 4-2L SE: What a masterpiece! Sigurd Ruschkow Solid State 58 27th January 2015 08:16 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 08:37 PM
Copyright 1999-2017 diyAudio
