Masterpiece
Masterpiece
Old 28th April 2013, 03:58 PM   #781
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
Originally Posted by RCruz View Post
Does reducing the riaa resistors and upping the caps also cause a higher amplification factor in this design ?
Can some of the findings here be tranposed to the original paradise ?
It's a fully balance design and don't really apply to paradise unless you start changing front end and then do fully balance also change current mirrors arrangement and change servo and then output stage...and finally change RIAA....ooppsss but then you have masterpiece!!!
Stefano
Old 28th April 2013, 08:01 PM   #782
Stefanoo's Avatar
And just FYI, halving resistors lowers gain so further adjustments were required to obtain the targeted 62.5dB (roughly).
Stefano
Old 30th April 2013, 12:25 AM   #783
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Ricardo, in the Paradise it is aprox. proportional. Lowering resistor values by a factor of two and raising cap values by a factor of two to get the same time constants lowers the gain by ca. 6dB.
Stefanoo, good you found the source of the distortion elsewhere.
I was running out of ideas how it could come from the Masterpiece.
Old 30th April 2013, 01:15 AM   #784
http://www.analogzone.com/col_01302004.pdf
Old 30th April 2013, 10:22 AM   #785
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Masterpiece
Thank you Joachim, do you believe that altering these values could also lower noise ?
RC
Old 30th April 2013, 01:32 PM   #786
When you lower the gain noise goes down too but you win nothing because you have to crank the volume of your preamp to get the same loudness.
It could be though that the noise in the bass goes down a bit.
A simulation has to be done to find that out.
Why Stefanoo´s Masterpiece is now so low in noise has to be checked.
I would need the current schematic with all transistors types and details again to simulate it.
Old 30th April 2013, 02:20 PM   #787
Stefanoo's Avatar
Originally Posted by Joachim Gerhard View Post
cool article!
Stefano
Old 30th April 2013, 02:29 PM   #788
Yes, i put it up for you because you asked me about thermal issues with Fets.
Feucht is a very good source for analog design.
Old 30th April 2013, 02:57 PM   #789
Stefanoo's Avatar
thanks.
Question, I remember finding a little curve traces USB that was pretty good for the money that was originally posted here on the forum by a chinese dude (I will look for that again and post it here)....
Anyway..I would like to ask what is the most used curve tracer here for matching BJTs?
Since Matching in this design is vital, I would like to match device properly on the next built, so I am looking for an inexpensive USB curve tracer that can get low power parts matched pretty well.
Stefano
Old 30th April 2013, 03:04 PM   #790
Stefanoo's Avatar
here is the thread:
DIY Curve Tracer for PC
also sells on ebay, I can't remember the name of it I have to find it.
I was thinking of getting one.
Do you guys think there could be something better than this for a reasonable price or this is reliable enough?
Stefano
MasterpieceHide this!Advertise here!
Lyra Connoisseur 4-2L SE: What a masterpiece! Sigurd Ruschkow Solid State 58 27th January 2015 08:16 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 08:37 PM
Copyright ©1999-2017 diyAudio
