Masterpiece
Masterpiece
Old 25th September 2012, 08:12 PM   #61
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
Originally Posted by Joachim Gerhard View Post
Stefanoo has the desire, i have the experience ......
thanks you are the Master!
Stefano
Old 25th September 2012, 08:26 PM   #62
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Masterpiece
The Pardise needs the big elcaps to make an AC path at the low frequencies. The high path is formed by the emitter impedance of the input stage in series with the electrolytics.. The formula is simply R x C.
So when R is low you need a big electrolytic or the gain drops in the bass.
There was no misunderstanding after all...
Stefanoo... how did you solve it without the caps then ? Is it because you are using fets ?
RC
Old 25th September 2012, 08:30 PM   #63
Stefanoo's Avatar
it is because I am setting an AC path to ground with the feedback resistor to ground.
This contribute to set the gain.
Now why it is not possible to obtain the same gain using a resistor instead of a capacitor goes beyond my understanding now.
Stefano
Old 25th September 2012, 08:33 PM   #64
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Question : To where do you like to reference your cartridge ?
Hint : floating will not work in a balanced stage.
Old 25th September 2012, 08:35 PM   #65
nhinstruments
RCruz's Avatar
Masterpiece
Thank you.. you are being really kind answering my nube questions.
I am learning a lot.
RC
Old 25th September 2012, 08:36 PM   #66
Stefanoo's Avatar
The cartridge IMHO will have to be conencted as shown on the circuit between plus and minus of the two halves and referenced to ground with the burden resistor.
Would this work?
Stefano
Old 25th September 2012, 08:37 PM   #67
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I am very interested. Brother is big vinyl guy. Just giving you hard time about the tiltle of the thread.
...Shape the sound , Man!
Old 25th September 2012, 08:38 PM   #68
Stefanoo's Avatar
no problem. I am a nubie too compared to Joachim and many others here
Stefano
Old 25th September 2012, 08:42 PM   #69
Stefanoo's Avatar
Then you are welcome in
Stefano
Old 25th September 2012, 08:52 PM   #70
Maybe the "burden" resistor forms a voltage divider with the cartridge.
MasterpieceHide this!Advertise here!
Lyra Connoisseur 4-2L SE: What a masterpiece! Sigurd Ruschkow Solid State 58 27th January 2015 08:16 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 08:37 PM
