Masterpiece
Masterpiece
Old 16th April 2013, 05:14 PM   #671
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Comes this evening. Sorry, i have a bad cold and i am not as fast as usual.
Old 16th April 2013, 05:45 PM   #672
MiiB is offline MiiB  Denmark
I believe the buffer is already posted if you care to read a little...
Old 16th April 2013, 06:20 PM   #673
OK, to avoid any confusion :
I build the driven BJT version. You can find that circuit on the " Simple Buffer Idea" thread
post 87 on the right side.
I use other semis though :
2SK369 cascoded with J310, i use a slightly weaker Zetex transistor from the same line.
Old 16th April 2013, 06:24 PM   #674
Bksabath is offline Bksabath  United Kingdom
Banned
MiiB is it possible to see J fets imput please?
Old 16th April 2013, 06:25 PM   #675
Go to this tread : Preamp-Buffers - simple idea
Go to post 87, you find schematic B : PP Hybrid Cascode Compound
Specific for FZT751 i use FZT753 because i had them, should not make a difference.
Old 16th April 2013, 08:19 PM   #676
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
Yes I have read that however Joachim said it was slightly different from that and I just want to make sure I build it e way he intended it.
Stefano
Old 16th April 2013, 08:19 PM   #677
Stefanoo's Avatar
Sounds good.
Stefano
Old 16th April 2013, 08:36 PM   #678
I think we have that clear now.
Old 16th April 2013, 09:17 PM   #679
Stefanoo's Avatar
Ok I will build that one in or next couple of days and I will post listening impression.
Stefano
Old 16th April 2013, 10:25 PM   #680
Fine, i hope you like it.
MasterpieceHide this!Advertise here!
Lyra Connoisseur 4-2L SE: What a masterpiece! Sigurd Ruschkow Solid State 58 27th January 2015 08:16 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 08:37 PM
