Masterpiece
Masterpiece
Old 16th April 2013, 01:28 AM   #661
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Read this review and also go the Simaudio website where they argue that DC coupling is better :
Simaudio Moon 810LP Phono Preamplifier | The Absolute Sound
Nevertheless, when you read the review carefully the biggest criticism is that the bass is rather dry. Why ?
Maybe too much precision buys you a sound that is very clean but also a bit threadbare.
A recording is music in a can. When we warm up the beans they will never taste like fresh. Maybe we have to add some spice to make it digestible. That is where art and the ear comes in. Why not trust your own ears ?
Old 16th April 2013, 01:32 AM   #662
There is even a thread about that problem right here on this forum :
Inherent Design Question: Inherent sonic characteristics that cant be measured?
I do not participate, not my kind of view but anyway, can we measure feelings ?
I do not think so. Ones a computer has passed the Turing Test i will resume.
Old 16th April 2013, 05:17 AM   #663
Bksabath is offline Bksabath  United Kingdom
Banned
I do not think so.
Maybe not with a stick or a pint glass but once one has been playing the game for a while one know if something is right.
So let them guide you and if you feel that something is not just quite right get the oscilloscope out.
Do you realy trust a simulation?
Old 16th April 2013, 11:57 AM   #664
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Refried beans.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 16th April 2013, 12:08 PM   #665
I work without simulation but i have a pretty good team that does that for me.
When the models are good simulations can be pretty accurate.
Usually i have a topological idea and build a prototype.
The simulation can then help to fine tune.
I trust nobody, not even me.
Old 16th April 2013, 12:17 PM   #666
Well, i trust my ears but so far i can not 100% predict how a certain circuit will sound.
One example : we designed a power amplifier with 4 people over a period of 8 years.
In that time the actual circuit diagram did not change much. We worked mostly on the power supply, the grounding and choice of passive components.
When i compare the sound of the original amp to what we have now the old amp sounds veiled and murky with week bass and dynamics only in the midrange. So you see topology is important but execution may be even more important.
Old 16th April 2013, 12:58 PM   #667
FdW is offline FdW  Netherlands
FdW's Avatar
Masterpiece
No, never, ever. But then again; do I trust myself? And the answer is 'No, Never, ever'. So how is this working for me? Most of the time I do the 'thought experiment' and then, to verify it, I use the simulator. This process is iterated many times, thought -> simulator -> thought -> simulator -> thought -> simulator -> ... Then one day I start building, measuring, and back to the simulator, and back to the thought experiment, and then it starts all over again.
As an example, building the current amplifier took me 5 years (not full time ) from which the first 3 years where 'thought experiment'-time, mostly making sketches, and reading books (Cordel, Self, Linear-Audio and more). This did make me think that they are wrong, they are using an existing principle and then they tinker until they like it. This is wrong (IMO) and I started reading any and all here on DiyAudio, and they are all wrong The next step is what then, if everybody is wrong what is good, and is it even possible to be good? I do not think so, at best you can be different and then, when different, you can try to do the best possible, and maybe, just maybe, it will be o.k. (not good, but o.k.) that is where I am now (after 3 versions of this amplifier).
The simulator is a tool, like a hammer, nothing more nothing less. The work is done in the 'brain'. Do I believe any of those (the tool(s) and the brain), no, I'm not a believer I'm an engineer (and will always be).
Just my opinion to answer the question. In the end you always will be wrong (somewhere) and that is good (and should be acknowledged).
I'm happy to be wrong, and I'm happy to (try to) do it better next time Please, let there be a next time!
Being wrong must be celebrated (FF ).
Old 16th April 2013, 01:44 PM   #668
Banned
Joachim Frans tanks for replies
IMO feelings on a very technical IMO at time alienating tread for the like of me that are more listeners of records (now that I don't make them anymore) and less proficient in electronics that most here.
Yes Frans we can only be a bit less wrong the next time around but we persist pester and make mistakes and eventually learn and came back for more.
Big Big Tanks to you Sirs.
Old 16th April 2013, 05:04 PM   #669
We talked about the J990 discrete opamp. Here is a lot of information and the circuit diagram :
http://www.johnhardyco.com/pdf/990-2007.pdf
Old 16th April 2013, 05:08 PM   #670
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
Schematic for buffer?
Stefano
MasterpieceHide this!Advertise here!
Lyra Connoisseur 4-2L SE: What a masterpiece! Sigurd Ruschkow Solid State 58 27th January 2015 08:16 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 08:37 PM
