Masterpiece
Masterpiece
Old 1st April 2013, 02:15 AM   #651
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
Originally Posted by Joachim Gerhard View Post
That is easy, it should be in the spec sheet, Good night.
I don't think data sheet there is very accurate.
I will double check there.
Have a good night!
Stefano
Old 8th April 2013, 12:48 AM   #652
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I build the Calvin super buffer and it works with some care to oszillation.
I will measure it later and listen tomorrow.
Old 8th April 2013, 12:54 AM   #653
Bksabath is offline Bksabath  United Kingdom
Banned
Right I tought that this tread was to quite for a while and was waiting to see the SCH on same Right Wing Italian Electronic magazine.
Old 8th April 2013, 12:58 AM   #654
I will publish the schematic here.
Old 8th April 2013, 01:01 AM   #655
Banned
Tank you Joachim
Old 9th April 2013, 12:59 AM   #656
Stefanoo's Avatar
There are different versions of that buffers, are you talking about the one on the first post?
Please show us schematic and your impression sound wise.
Stefano
Old 15th April 2013, 11:28 PM   #657
I have now decided what version of the buffer i like best or better that works best to me.
It is the BJT version. I am using a bit different semis then Calvins schematic so i will publish the exact circuit i build. I can not overlook if changes to that circuit give the same result so when you want the same result that i got you have to build it my way.
My circuit produces around 5mV DC offset but that can be trimmed.
Old 16th April 2013, 01:51 AM   #658
Stefanoo's Avatar
Ok I will give it a try.
Given we have the servo 5mV shouldn't be a problem.
However I was thinking to move the input of the servo at the input of the buffer and give it a listen.
In that case I will need to trim the output if the buffer!
Do you have any clue whether moving servo will impact sound at all?
I am a curious person always like to try new things
Stefano
Old 16th April 2013, 02:15 AM   #659
Why servos have an impact on the sound ?
It is an active element that can add distortion and somehow it is in the feedback chain.
When a single resistor makes a difference then a active element can do more.
Old 16th April 2013, 02:23 AM   #660
Another view :
The servo extends the response in the bass.
That can be a good or a bad thing.
MasterpieceHide this!Advertise here!
Lyra Connoisseur 4-2L SE: What a masterpiece! Sigurd Ruschkow Solid State 58 27th January 2015 09:16 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 09:37 PM
