Masterpiece
Masterpiece
Old 28th March 2013, 03:52 AM   #601
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
Originally Posted by Joachim Gerhard View Post
Yes, i build it and others. Here in the german DIY scene it even is a bit famous.
It won several contests.
The " Hawksford" connection has a positive influence on the sound in the bass my sources told me.
Did you build it with 8 pairs of Jfets?
What would the reason be for having so many paralled Jfets?
Do you think there is a true sonic benefit from having so many paralleled devices?
I am wondering if to drive a regular premplifier, which in the worse case could present 20-30Kohm of impedance we require an output stage capable of 40-50mA?
Stefano
Old 28th March 2013, 03:57 AM   #602
Stefanoo's Avatar
I will post here the buffer Joachim is referring to.
Stefano
Old 28th March 2013, 08:41 AM   #603
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Buffers are one of my hobbys you know so at the beginning of the MPP thread i published a lot of buffers and several people build various versions. The buffer you just posted won the listening contest.
This is now more then 2 years agao.
Yes, i build it with 5 pairs of Fets in parallel.
Do i think that this sounds better then only one pair ?
That depends on how much current we draw.
By the way i find the Paradise buffer transparent in most cases and as good as the
Hawksford.
Old 28th March 2013, 09:05 AM   #604
dadod has just posted an improved version of the buffer.
I will try this out.
Old 28th March 2013, 09:53 AM   #605
Bksabath is offline Bksabath  United Kingdom
Banned
Originally Posted by MiiB View Post
hmm... Gain is a question of scaling the riaa ccomponets, I have a Paradise with Jfet input and 65dB gain at 1Khz. 2 set in parallel each running at 7 mA
Wuld it be possible to try this out Please?
PM maybe...
Old 28th March 2013, 01:56 PM   #606
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
It's either noise level, multiplying transconductance, or stacking current.
A buffer with high drive capability is never a bad thing, ime, even for phono duty (inbalance percentage of a V8 versus a 2-cylinder four-stroke)
Eight in parallel would be totally unstable, only works with BJT's.
(Accuphase manages 3 parallel J108/K370)
Old 28th March 2013, 05:28 PM   #607
Stefanoo's Avatar
Interesting! I guess I will have try try it!
Stefano
Old 28th March 2013, 06:04 PM   #608
Elementary, a buffer only has local feedback.
Old 28th March 2013, 09:40 PM   #609
Stefanoo's Avatar
quoting from the other post:
John seems to like the type "A" circuit:
http://www.diyaudio.com/forums/analo...ml#post3431096
Stefano
Old 28th March 2013, 10:50 PM   #610
There's just one little problem with it.
MasterpieceHide this!Advertise here!
Lyra Connoisseur 4-2L SE: What a masterpiece! Sigurd Ruschkow Solid State 58 27th January 2015 08:16 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 08:37 PM
