Masterpiece - Page 5 - diyAudio
Old 25th September 2012, 04:48 PM   #41
Stefanoo's Avatar
Granted that ultimately precision and tweaking of the RIAA is done on the circuit with proper set up and equipment and not only driven by the simulation's tool.
What I find is that, usually, you can compensate a little bit with resistors and having custom values for caps and resistors is the optimal solution.
Once you determined on the circuit your ideal values that gives you the best RIAA recontruction you order the custom or you try to get the closest one and see if you can adjust with resistors.
Stefano
Old 25th September 2012, 04:48 PM   #42
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by Stefanoo View Post
On the other hand, also experimented with this, if from one side you get more benefit by paralleling more JFETs in terms of a bit darker background, from a sound standpoint, 4 paralled trannies yeald to a duller sound than a pair in front with a tad more degeneration and more gain distribution.
Now this is very revealing.... Thank you so much Stefanoo
RC
Old 25th September 2012, 04:56 PM   #43
Joachim Gerhard's Avatar
I do two stage RIIA´s and one stage too. I general i prefer the simplest signal path as possible provided that distortion is under the audible limit.. Usually it put the 75usec in the first stage because that gives a better overload margin where it counts, suppressing bad effects from scratches and dirt.
Old 25th September 2012, 05:00 PM   #44
By the way i do not have audible problems with electrolytics and coupling caps when they are used in such a way that they do not produce distortion. Servos have their own issues.
Best would be DC coupled without servo but that is hard to do with high gain circuits. I have done that in my line stage and in my power amps that have very good thermal stability because i use lateral mosfets. This kind of circuits can be hand trimmed without much drift.
Old 25th September 2012, 05:21 PM   #45
nhinstruments
RCruz's Avatar
I agree
The network that gives the 2122Hz corner (or 75uS) should be placed first because the signal coming off disc has its highest amplitudes at high frequencies, so we wish to avoid high frequency overload in our gain stages so we filter it before it becomes to large. The second reason is that we wish to defer filtering the low frequencies until we have amplified them up to a reasonably healthy level.
RC
Old 25th September 2012, 05:28 PM   #46
nhinstruments
RCruz's Avatar
Now the big question...stefanoo removed the EL caps and got lower amplification but Joachim told me these are responsible for the bass response.. What am I missing ?
RC
Old 25th September 2012, 07:18 PM   #47
Stefanoo's Avatar
Joachim, thanks for your contribuite.
I haven't experimented with this topology yet in term of sound, and I am going to have a paradise's prototype ready for listening by tomorrow and then start swapping parts.
If from one side I agree with you, on the other hand I think that capacitor most of the time leave a sonical trace and most of the time is not measurable at all not in terms of frequency response nor distortion wise.
For example, different PSU filter cap.
You can explain certain things with ESR, capacitance value Ripple current, but, given pretty much the same specs, common practice suggests that they sound some time pretty different one from another.
This is my take so far and it can be wrong or impartially incorrect but it is what I know so far
Said that I can't imagine the boosting capacitor not leaving any significant trace on the sound and if it doesn't I will be extremely pleasantly surprised.
A straight test I am going to run is to have same values but different type, perhaps Panasonic FC and some cheapo nasty cap.
If there is no significant impact then I will change my approach on caps.
Stefano
Old 25th September 2012, 07:21 PM   #48
Stefanoo's Avatar
The network that gives the 2122Hz corner (or 75uS) should be placed first because the signal coming off disc has its highest amplitudes at high frequencies, so we wish to avoid high frequency overload in our gain stages so we filter it before it becomes to large. The second reason is that we wish to defer filtering the low frequencies until we have amplified them up to a reasonably healthy level.[/QUOTE]
That is a good thought behind it! There is no end to learn; I would have done the other way around to filter better at the output high frequency noise.
However it just makes a ton of more sense to do it the way Joachim suggested.
Stefano
Old 25th September 2012, 07:29 PM   #49
Stefanoo's Avatar
Maybe there was a sort of misunderstanding between you and Joachim.
In short, I am unable at this point to tell you exactly what the rule of these capacitors on the transfer function is unless I calculate it (which I might due when I get some spare time).
What I can tell you is that these capacitors are responsible for the bass response but at the same time, if you take them off your gain drops down, and you need a way to set your AC gain which you do it by inserting the resistor from the midpoint to GND.
You can see the effect of it if you model the circuit on the simulator, which is what I have been describing above.
Stefano
Old 25th September 2012, 07:40 PM   #50
nhinstruments
RCruz's Avatar
I have heard it argued that the stages should be the other way around because putting the HF filtering second will help reduce noise - this is possible but just ignores the reasoning above.
RC
Lyra Connoisseur 4-2L SE: What a masterpiece! Sigurd Ruschkow Solid State 58 27th January 2015 08:16 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 08:37 PM
Copyright ©1999-2017 diyAudio
