Masterpiece - Page 28 - diyAudio
Old 16th October 2012, 08:05 PM   #271
Stefanoo's Avatar
Originally Posted by Joachim Gerhard View Post
He is moderator there. He talked about that circuit too here on DIYAUDIO in the old times.
Sorry, i am not very helpful at the moment. Have a ton to do.
I will try to look for it...if and when you have chance if I haven't found it yet and you have instead, please post it on here
Thaankkss
Stefano
Old 16th October 2012, 08:07 PM   #272
Joachim Gerhard's Avatar
I only remember that he posted that this is a superior circuit.
Old 16th October 2012, 08:26 PM   #273
Stefanoo's Avatar
and it looks so interesting. Do you remember other details on the post? like title fo the thread?
I tried to google but I was unable to find anything related!
Stefano
Old 16th October 2012, 09:03 PM   #274
You can go to the members area and find his name. Then you can find his posts. Sorry but i do not have the time to do the detective work unless you pay me (-:
Old 16th October 2012, 09:16 PM   #275
Stefanoo's Avatar
ahahahahah!! I will do the detective although I have no license so I hope I won't brake the law!!!
was his name by chance:
Elso Kwak?
Stefano
Old 16th October 2012, 09:25 PM   #276
Maybe you can start here :Re: 2SK117 or 2SK170 input stage?Better use 2SK389 - Elso Kwak - Tweakers' Asylum
Old 16th October 2012, 10:07 PM   #277
Stefanoo's Avatar
That is the same post I was looking at I think.
On that post there is a mention on page 6 that change the 3.9 Zener with string of diodes leads to same low noise and same sound quality.
So I figure out what the circuit was missing: the 3 LEDS.
Why is that I don't understand....but here it is....
Stefano
Old 16th October 2012, 11:54 PM   #278
Stefanoo's Avatar
I am in the meantime shaping out in my mind how masterpiece can be laid out.
These are my two cents feel free to comment.
I have noticed that it is very hard to design an MC stage with enough gain with relative simple circuit (except for paradise) or at least with the different circuits we explored so far I am sure there are better ways out there I simply don't know them.
Anyhow this latest circuit seems to be very suitable for a mc section with cascoded monolithic 2SK389 and a gain of 49dB roughly. I will have to find a way to make it fully differential though.
This stage followed by a passive differential 75uS time constant feeding masterpiece rev 7 with only n-ch with maybe one or two 2sk389 (if a gain of 35-40 dB can be reached out that way) with trans z rest of the RIAA in fully balance configuration.
This is my thought so far, thus a 2 gain stages with split RIAA which circles back out with the first disclaimer in my first post .
What do you guys think? Does this idea have the potential for being a very low noise and distortion mc phono stage?
Stefano
Old 17th October 2012, 02:21 AM   #279
Yes, i would go for a two stage design. I would do the 75usec transimpedance first and then the rest active ( feedback ).
Old 17th October 2012, 03:13 AM   #280
MiiB is offline MiiB  Denmark
just like I Said.. two stage...high cut between the legs and active feedback in the second op-amp stage... let the first stage run without the feedback, as the signal levels are so low the distortion would be fairly low, noise sort of highish. (if you use the LSK or SK fets. (interfet would be interesting and lower in noise)
second stage would then have the base shelf as a part of the feedback network..
what you would then have is a floating input. (not balanced) and a single-ended output. Performance would in my objective be good. (One shot is still a more novel circuit.)
Lyra Connoisseur 4-2L SE: What a masterpiece! Sigurd Ruschkow Solid State 58 27th January 2015 08:16 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 08:37 PM
Copyright 1999-2017 diyAudio
