Masterpiece
Masterpiece
Old 16th October 2012, 03:31 PM   #261
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
But seriously, I can't make that circuit work for some reason.
Have you tried yourself to simulate it?
Did you succeded?
Stefano
Old 16th October 2012, 03:41 PM   #262
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Stefano, have you tried to make both voltage sources at the input positive ?
Old 16th October 2012, 03:46 PM   #263
Stefanoo's Avatar
I just tried all 4 combinations for the 2 input generators, but it doesn't seem to work.
Stefano
Old 16th October 2012, 03:58 PM   #264
There was a guy, i think his avatar is Elso Quack, that worked with this circuit.
I think he has his own blogg now so you have to find him.
Old 16th October 2012, 04:16 PM   #265
MiiB is offline MiiB  Denmark
I would make it like a two stage.. first stage with the high-cut part of riaa between the legs...then folded over in the opamp.. with a local feedback there making the base part active.
You generators are canceling... so both legs are seeing the same signal. need to phaseshift one 180 degrees.
Old 16th October 2012, 04:18 PM   #266
I found him here :DIYHiFi.org • Index page
Old 16th October 2012, 04:35 PM   #267
RCruz is online now RCruz  Switzerland
nhinstruments
RCruz's Avatar
Masterpiece
PTFE
RC
Old 16th October 2012, 04:44 PM   #268
Stefanoo's Avatar
Interesting concept.
Otherwise is it possible top create out of this a differential folded cascode with transimpendance RIAA? something to think about.
If I pass the hump to simulate the plain scheme I can try to work that around.
For the generators, they are out of phase.
Stefano
Old 16th October 2012, 04:44 PM   #269
Stefanoo's Avatar
That is the forum DIYHIFI. Did he have a topic opened?
Stefano
Old 16th October 2012, 05:16 PM   #270
He is moderator there. He talked about that circuit too here on DIYAUDIO in the old times.
Sorry, i am not very helpful at the moment. Have a ton to do.
MasterpieceHide this!Advertise here!
Lyra Connoisseur 4-2L SE: What a masterpiece! Sigurd Ruschkow Solid State 58 27th January 2015 08:16 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 08:37 PM
