Old 15th October 2012, 06:55 PM   #241
Stefanoo's Avatar
Originally Posted by Joachim Gerhard View Post
When i think more about it maybe there is simply too little current in the input stage.
I have 40mA running on the input stage with 6 BFs each side.
Stefano
Old 15th October 2012, 07:10 PM   #242
Stefanoo's Avatar
Acting on the input current acts on the gain.
With 6 BFs 3.3ohm degeneration and 60mA LTP I get 63dB.
63mA per side is a huge amount of current. hmmm!!!
anyhow increase of input current and sqeezing everything to the max, it looks like there is not so much gain avaialbe anyway.
Stefano
Old 15th October 2012, 07:17 PM   #243
Joachim Gerhard's Avatar
For high Gm you need a lot of current that flows in the Fets. A bipolar has 10x higher Gm for the same current so with bipolars you have a much better relationship of idle to Gm.
That is unavoidable.
Old 15th October 2012, 07:27 PM   #244
Stefanoo's Avatar
true consideration.
Then can this be re-arranged for BJT?
It is a thought I am considering now since the many disadvantages I am encountering with FET, i.e. : of low gm, problem driving a lo Z source, avaialability.
What is your thought on this?
Stefano
Old 15th October 2012, 07:28 PM   #245
Sure, you can use a bipolar long tail pair but then you have the issue of input DC.
Old 15th October 2012, 07:31 PM   #246
Stefanoo's Avatar
DC offset seems to be a minor ptoblem compared to the others. I don't know what you think.
I am trying to re-arrange it but I can't make it properly operate.
Stefano
Old 15th October 2012, 07:32 PM   #247
This has to be rearranged to balanced but it shows the principle.
Old 15th October 2012, 07:34 PM   #248
Old 15th October 2012, 07:36 PM   #249
Stefanoo's Avatar
Is it a scan of the linear audio issue you have recommend? I didn't have time to order it I will do it today and get over with.
I would like to know your opinion if for this balance desing you think we should persue the scheme in rev 7 and try the InterFet device or re-arrange for a differential BJT kind of technology.
Stefano
Old 15th October 2012, 07:41 PM   #250
I am eager to see the Interfet at work, bipolar works anyway. That is always an option and i did it in the Paradise.
See an even better bipolar low noise circuit. Forget the post before.
Lyra Connoisseur 4-2L SE: What a masterpiece! Sigurd Ruschkow Solid State 56 18th April 2013 08:23 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 08:37 PM
Copyright ©1999-2013 diyAudio
