Masterpiece
Masterpiece
Old 24th September 2012, 08:39 PM   #11
pdul is offline pdul  Denmark
Maybe a linestage to complete the Paradise
Old 24th September 2012, 08:41 PM   #12
Maybe some jfets where p and n are more available?
Old 24th September 2012, 08:43 PM   #13
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
Originally Posted by RCruz View Post
This looks like two paradise boards connected at the same time to one cart side output...
Am I too far away ?
There is the caveat where the feedback connected serves to lower distortion of the two halves and also allows you to run it either SE or Bal.
Other than that it is using the basic structure of the Paradise. Servo is different to accomodate Differential outputs.
Also it is going to be 2 stage without the "boosting" capacitors and two TransZ networks for max precision and fitting standard capacitors.
Stefano
Old 24th September 2012, 08:44 PM   #14
Stefanoo's Avatar
The final view or take here is that the gainstage that will be developed here for this project will be and can be used then as extension to develop a linestage and a power amp.
However, let's take one step at a time
Stefano
Old 24th September 2012, 08:45 PM   #15
Stefanoo's Avatar
unfortunately not that I know of, but again there are still available k170 and j74 that can easily be had!
Stefano
Old 24th September 2012, 08:53 PM   #16
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Ricardo, you are right. Theoretical it is possible to make a balanced stage with 4 Pardise boards and some changes. Stefanoo though has something more ambitious in his mind.
Good luck !
Old 24th September 2012, 08:53 PM   #17
Stefanoo's Avatar
Here is the circuit in a SE faschion just to show how the RIAA is going to look like.
I have run frequency response's simulation and precision with this arrangement and values is over the top and like you can see it uses standard capacitors to achieve that.
Muy concern here is the noise and as the simulation shows, noise is way too high for a low noise MC amplifier.
Any input is welcome.
Stefano
Old 24th September 2012, 09:26 PM   #18
Stefanoo's Avatar
Anybody has any input as far as output noise is concerned and/or eventual improvement to the design? Any question so far? Need output scope shots or spectral density view, distortion or anything else I can provide to get this going?
Stefano
Old 24th September 2012, 09:28 PM   #19
I have to study that complex circuit in detail but i also have to prepare for a show in Venthoven this weekend. I will jump in when i find the time.
Old 24th September 2012, 09:31 PM   #20
Why are the 2SJ74 connected to the cascodes with the sources ?
MasterpieceHide this!Advertise here!
Lyra Connoisseur 4-2L SE: What a masterpiece! Sigurd Ruschkow Solid State 58 27th January 2015 08:16 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 08:37 PM
