Masterpiece
Masterpiece
Old 22nd June 2013, 01:44 PM   #1301
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I used Dale RN60D 1/8W 1% 100ppm, very good sound: I used at my first stepped shunt attenuator, second and last with Shinkoh both with Shallco rotary switch. I never used Melf resistors. Another good sounding resistor is Vishay VSH bulk foil radial conformal coating 0.3W values from 5R to 120K
5-50K 3$95
51-75K 4$95
76-120K 6$50
Seller Michael Percy Audio USA http://www.percyaudio.com/Catalog.pdf
I'm not affiliate with him, simply I'm a satisfied customer.
Old 22nd June 2013, 02:24 PM   #1302
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
OK; then you already know your choices.
Old 23rd June 2013, 04:42 PM   #1303
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Masterpiece
Originally Posted by Stefanoo View Post
Can you hear Mozart?
Good luck listening to the Shunt when noise is on the order of 50uVpk-pk!
No I am searching for other types of sounds, like squeals, buzzes etc.
I normally use a headphone amp... if I can hear no ripple and no whistles, it seems ok to me
RC
Old 23rd June 2013, 05:33 PM   #1304
Yes, then you have additional amplification of the signal.
Old 25th June 2013, 02:42 PM   #1305
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
I took these pictures yesterday and like them and just thought of sharing them here...and it would be cool to share set ups pictures too..
Stefano
Old 25th June 2013, 02:46 PM   #1306
cool, there are so many new turntables out there.
I am loosing the overview.
Old 25th June 2013, 08:36 PM   #1307
Stefanoo's Avatar
Thanks!
Yes there are so many out there that it is hard to keep up with!!!
Stefano
Old 19th July 2013, 08:34 AM   #1308
JBdV is offline JBdV  Netherlands
Masterpiece
Master ?????
Old 19th July 2013, 04:21 PM   #1309
carolus is offline carolus  Belgium
Hi Stefano,
Is that yours TT with a (air bearing) "Terminator".
Nice.
What kind/type of card ?
The best.
Karel
Old 24th July 2013, 01:20 AM   #1310
Stefanoo's Avatar
Originally Posted by carolus View Post
Hi Stefano,
Nice.
The best.
Karel
Yes it is a special version of terminator, sounds fabulous.
My cartridge is a modified zyx 4D. The modification from expert stylus brought up performance a couple of notches from original profile.
Stefano
MasterpieceHide this!Advertise here!
Lyra Connoisseur 4-2L SE: What a masterpiece! Sigurd Ruschkow Solid State 58 27th January 2015 08:16 PM
A new masterpiece to add to the family... Guiness Tubes / Valves 20 2nd May 2003 08:37 PM
Copyright ©1999-2017 diyAudio
