Old 19th September 2012, 01:45 PM   #11
Pano is offline Pano  United States
Pano's Avatar
Nice. Good luck with the recordings, i'd like to hear them. Years ago I had a set of expensive "earbud" style mics that worked in a similar way. The recordings were very nice.
Old 19th September 2012, 02:09 PM   #12
Aye, I've got a nice pair of Roland CS10EM ear mounted mics, they do a lovely job. The head has the advantage of incorporating replica ear canals for vertical localisation, as well as obvious being a free-standing mic.
This recording was done with the Rolands mounted inside a dummy-head:
Binaural Birds by Nathan Gallardo on SoundCloud - Create, record and share your sounds for free
I'll definitely be back with some more in the next few days
Old 19th September 2012, 02:44 PM   #13
Pano's Avatar
Nice. It is natural enough that I had a hard time differentiating it for sounds around me.
I liked the bee. Listened on Sony headphones, will listen on the big VOTT rig tonight.
Old 19th September 2012, 03:00 PM   #14
scott wurcer's Avatar
Originally Posted by Poxican View Post
Hmm I swapped the connections around on one of the capsules and it seems to have sorted it.. going to solder it up properly this morning and see how it goes. Looking at all the wiring diagrams for the mod I can see what you mean, it does look like I did it back to front!
Is there any chance I'll have damaged the capsule by having it wired back to front?
Very unlikely.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 25th September 2012, 06:14 PM   #15
So that has definitely made an enormous difference. It no longer breaks up at speaking levels as it was before. So thanks Scott for helping me fix the capsule issue. However, it seems there was another issue involved which has only now become apparent.
I've been testing it with two devices: a Zoom H4 and into my Focusrite Saffire 6.
I don't think the Zoom is any good for the head. Shouting at the head creates distortion on the Zoom recordings, but I believe that's the Zoom as opposed to the capsules. It only has 3 input settings, low-medium-high, and an in-menu input level which is digital and hence useless. I understand my circuit outputs a line level signal (I'm looking to you for confirmation here....) and the Zoom inputs are mic level, so while it'll be fine for recording ambience and whatnot but it'll be no good in a gig setting. It even distorted recording a noisy corridor at uni today. Any fix for this?
Into my Saffire 6 is much better, but still seems problematic. With gain set to zero and the pad initiated it still seems to distort a little if I shout into the mic. It's not peaking in Logic or on the interface, so I presume it's happening at the capsule. That said, I'm not sure if the mic should be able to handle that kind of level? Is it realistic to expect it not to break up if I shout directly into it? I did a short recording so you can hear the breakup:
ClapsTesting01 by Nathan Gallardo on SoundCloud - Create, record and share your sounds for free
Those are the hardest claps I can muster at the beginning, followed by my shouting into the ears. This isn't very scientific I know...
Any thoughts?
Old 25th September 2012, 06:36 PM   #16
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Quite frankly, I cannot hear the overload.....????
Build yourself a decent preamp with padded variable output. TL072s, 5534,5532 or even some of the SSM chips should do the trick of optimizing input volume.
This might also give you some ideas
D.I.Y. Recording Equipment | DIY Microphones, Preamps, Compressors, etc.
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 26th September 2012, 10:15 AM   #17
Really? There's very noticeable distortion on the 'testing' shouts.
It doesn't seem to be peaking in Logic though, so I can only assume it's the capsules. But I thought the Linkwitz mod would allow them to stand up to that sort of level...
Old 29th September 2012, 04:12 PM   #18
Sorry to bump this but I'm still having some troubles :/
I tested the mics in front of a PA the other day and they held out well, but they still broke up at high volume, and I'm certain we didn't reach the 130db limit these capsules are meant to be able to handle post-Linkwitz.
I've measured the voltage across the capsule while powered, ie. between terminals 1 and 2, and it reads consistently at around 14v. This definitely seems wrong, though I worry I am taking the measurement incorrectly.
If that is the correct way to measure the voltage, what would that reading indicate? That the capsules are receiving too much power? What could be the cause for that in the circuit?
I'm sorry for all the novice questions, I really appreciate your efforts to help me though!
Old 29th September 2012, 06:42 PM   #19
Mooly's Avatar
The voltage across the capsule must be within the recommended limits for the particular device.
Refering to your original diagram in post #1 the voltage across the capsule is determined by the 33K and the two 5K6 resistors. If you have used a different capsule to the one the circuit was designed for then the voltages will be different as the capsule will probably have a different current draw.
Altering the 33K will alter the voltage across the capsule. Higher t'ohmage and the lower the volts on the capsule.
A simulation free zone. Design it, build it, test it.
Old 29th September 2012, 06:46 PM   #20
Pano's Avatar
I thought these capsules wanted about 5V. No?
First post and need help: Creating Binaural Mic! Prismatic Everything Else 5 31st July 2010 02:37 PM
Binaural recording: alternatives to expensive dummy heads? KT Everything Else 11 7th September 2006 09:30 PM
Head Phone AMp / Mic jleaman Everything Else 3 14th April 2006 04:48 PM
Alternatives to the Panasonic WM-60/61 mic capsules percy Everything Else 0 29th March 2006 03:23 PM
chinese mic capsules rafafredd Parts 3 4th February 2003 04:31 PM
Copyright ©1999-2013 diyAudio
