What price to pay for a Thorens TD166 MkII
I have one of those, but I bought it 20 years ago and so have
no idea what it might be worth today. I am not sure what you
mean by the extras though. Extra steel platter? The anti-skating
weight should be included originally. There is a small one, and a
larger one that fits aroung the smaller one, if you need
a heavier weight.
analog_sa said:
I would think this is a steel (alu) subplatter - it originally uses a plasic one and the metal is known to sound better and closer to the 160 big brother. About $150 is the max sane price to pay for it.
Aha, you mean a steel replacement for this plastic hub in
the middle?
Sounds like an interesting tweak. I have an uncle who could
probably have done one for me at work. unfortunately he is
retired now. :(
This thorens has an external trafo, right?
I own a TD160MK1, and the motor is line rated, but maybe yours is 16V. If so, you can easily build a signal generator and get the mains distortion out of your synchronous motor. With mine the results are that the motor doesn't bzzzz any more, even with a stethescope in the shaft.
I recomend it if your to do list is starting to get empty.
