turntable design and build
Old 11th September 2012, 08:51 PM   #11
ijpdesign is offline ijpdesign  United States
Aurora-
Any drawing would be of great help and I am in no rush as I am still in the research and development stage, which seems like I am in a constant state there of. I could really use a platter drawing, the bearing I am going to buy but if your drawing of the bearing will help me to further understand the design concept I would happily look at that as well.
Thanks so much for your help!!!
Old 11th September 2012, 09:05 PM   #12
bbftx is offline bbftx  United States
bbftx's Avatar
Default Acoustic Signature Final tool
ijp
The turntable in my original message is manufactured by Acoustic Signature, a German outfit. I bought one and have modified it a bit. I fabricated a round tonearm mount for the Graham tonearm in the attached photo, then more recently, I built a new outrigger arm and tonearm mount (the big round cylinder) on which the Trans-Fi Terminator linear air bearing tonearm sits (great model for a DIY tonearm project too!)
Since it's a manufactured table, I don't have drawings, but the platter is 12-3/16" in diameter. It's just a hair under 2" tall.
In terms of getting the motor and spindle bearing lined up, and getting tonearm-to-platter geometry set, the answer is to build adjustability into the design:
The 3 spiked feet underneath the platter base on the Final Tool are adjustable. This allows you to level the table, but would also allow you to precisely set the relation between motor height and platter spindle bearing if you wanted. The outrigger arm on which my tonearm is mounted to the platter base with bolts has slots instead of just holes. With the slot, you can adjust the effective length of the outrigger to set your tonearm pivot wherever it needs to be for the tonearm you want to use.
BB
Old 11th September 2012, 09:20 PM   #13
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
ijp - drop me PM with your regular E-mail........
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 25th September 2012, 07:08 PM   #14
j0nas is offline j0nas  Lithuania
look site Welcome to the Frontpage
Old 10th October 2012, 06:40 PM   #15
smith01793 is offline smith01793  United Kingdom
Default D.I.Y. Thorens based gyrodec tribute with Ladegaard arm
I built my own turntable a couple of years ago, based on a Thorens td160 that I have had for years that was looking a little worse for wear. I used the platter and bearing + motor and springs, styled on the Gyrodec by Mitchell the base is made from mdf spray painted silver. Originally I had used the thorens arm but recently I built my own arm based on a design by Poul Ladegaard.
If you are going to build your own turntable I seriously recommend you look into this arm and Incorporate it into you final design, the arm you can see in the picture cost less than 50 to build and this includes 25 for the air pump it can be built using simple tools (drills junior hacksaw etc.) and it sounds great most noticeable on the final tracks on Lp's where the zero tacking error digs out extra detail that is normally hidden by by the more compressed inner grooves.
Any Progress is Progress
Old 18th October 2012, 12:06 AM   #16
YNWOAN is offline YNWOAN  United Kingdom
YNWOAN's Avatar
Unfortunately, building a turntable is not really like building a piece of furniture (for example), it very much more like constructing a hybrid between a piece of precision measuring equipment and a musical instrument. Any, 'how to' plans are likely to be extremely simplistic and gloss over, or ignore, the significant complexities at work. Ultimately, it depends on how high a performance level you wish to achieve.
This deck has been in development for nearly 20 years and even since this picture was taken the record clamp has been improved and so has an element of the drive system.
Old 18th October 2012, 12:21 AM   #17
R.I.P.
Style over substance is endemic in general turntable design, and sorting
the style from the substance not easy, and mainly a very personal task.
Experimentation is better than dogma, I've built / rebuilt a few and
have some idea what works for me, but nowhere near definitive.
rgds, sreten.
Old 18th October 2012, 12:25 AM   #18
YNWOAN's Avatar
Indeed, most DIY turntable projects that I have seen essentially seek to emulate the aesthetic of an existing design without addressing the design precepts (which is inside out as far as I am concerned).
turntable design and buildHide this!Advertise here!
Turntable design theory SevenPointSixTwo Analogue Source 30 9th December 2013 06:12 PM
Masonry type question for Turntable build. JoshK Equipment & Tools 8 13th July 2010 04:55 AM
The build starts. (DIY Turntable) kilowattski Analogue Source 19 20th May 2008 01:31 PM
Uni project about Turntable design... calummckenna Analogue Source 8 11th February 2008 08:05 AM
turntable bearing design sc351cobra Analogue Source 1 24th March 2005 11:30 AM
