Strange Features by the MC Head Amp Circuit of Linn's LK-1 (LK1) - diyAudio
Old 31st August 2012, 04:38 PM   #1
tiefbassuebertr's Avatar
Default Strange Features by the MC Head Amp Circuit of Linn's LK-1 (LK1)
This amp stage consists of a differential cascode and instead the usual current source of the LTP there are two independend CCS. This means, one can adjust the open-loop gain by variation of the value from R6.
The question for me is which job does the jumper with ferrite beads like
http://www.wb5rvz.com/sdr/genesis_g4...rrite_bead.gif
or
http://www.token.com.tw/inductor/ima...filters-fb.jpg
(on Main PCB called "LK1" = link1), solder in parallel mode to R6 ??
In the attached picture you will find the Tantal C2 between the phono input RCA sockets. "LK1" with ferrite beads and "R6" (3R3) you will find in the right of C2.
And some more questions:
Linn don't prefer a dc coupled mode. The choice of the capacitor in the signal pad (and NFB) are 100uF tantal in parallel mode with a 22uF tantal.
1) Are there a special benefit for this kind of parallel mode?
2) By which guidelines was fixed the polarity ??
3) How is to determine the voltage gain factor of this stage?
4) There are a ferrite bead on each base leg from Q3 and Q4 (2x CCS). Why?
P. S. Linn's LINTO (first series) uses the same circuit topology (some versions without the ferrite bead).
Old 7th September 2012, 09:09 AM   #2
no informations?
the genuine circuit is here:
http://diagramas.diagramasde.com/audio/Linn%20LK1.pdf
Old 13th September 2012, 11:26 AM   #3
ticktock's Avatar
I'm also highly interested in any information about the LK1.
I did some mods on the LK1 more than 10 years ago and hope to find some pics of these.
Old 14th July 2013, 08:47 PM   #4
ticktock's Avatar
Anything you'd highly recommend to change on the line and output stages?
thanks
Blaue Leuchtdioden machen blöd. (hb)
sent from NSA monitored device
Old 25th November 2014, 05:27 PM   #5
until know I haven't get the wanted informations (go to post #1).
Where are the experts?
Old 25th November 2014, 06:02 PM   #6
diyAudio Moderator Emeritus
jean-paul's Avatar
No expert but ferrite beads are used to filter HF/RF out. Maybe to avoid oscillation ?
It's only audio. Member of the non modular PCB design committee
Old 27th November 2014, 06:26 PM   #7
kevinkr's Avatar
The beads (usually very lossy) are used both the prevent oscillation and to reduce susceptibility to external EMI.
Paralleling different values of electrolytics is usually done to reduce the effects of parasitics in the capacitors in very low level, low impedance circuits. (or in power supply decoupling to assure low decoupling impedances over wide frequency ranges - the danger in doing this is ESL in the large capacitor my resonate with the smaller capacitors, there are techniques to deal with this) I use this technique with very large electrolytics.
Tantalums are a pretty lousy choice for audio coupling caps due to some inherent distortion generating mechanisms particularly with small values of DC across the cap. Oscons or low impedance AL electrolytics may be a better choice if chosen appropriately.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th November 2014, 07:44 PM   #8
jean-paul's Avatar
Same meaning, different words
BTW modern tantalum caps perform much better than described....
What features would you like in a head unit that doesn't exist yet? JZatopa Car Audio 18 15th March 2011 06:18 PM
Linn LK1 LK 1 Record - and Source-Indicator LED's wanted tiefbassuebertr Solid State 0 5th April 2010 05:47 PM
Zobel filter for MC head amp? duderduderini Analogue Source 3 15th December 2008 09:31 PM
MC head amp rdr Analog Line Level 29 27th December 2006 09:21 PM
Low noise head amp (MC) Jorge Analogue Source 11 19th August 2005 02:14 AM
Copyright ©1999-2017 diyAudio
