Paradise Builders
Paradise Builders
Old 9th January 2013, 02:14 PM   #981
chiily is online now chiily  United Kingdom
Originally Posted by analog_sa View Post
Wow. The simulated waveform is very similar to what i see on the scope. Seems like the simulation predicts something like 4MHz, right?
Looks close to what I see too...
Garf.
Old 9th January 2013, 02:19 PM   #982
PMA is offline PMA  Europe
PMA's Avatar
Paradise Builders
Thanks for the feedback, guys. Though there was a lot of emotions, please believe me that I would like to give a helping hand and such a help should be an engineering analysis as a basis for the issue solution.
Old 9th January 2013, 05:19 PM   #983
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
Originally Posted by FdW View Post
Thanks, I will try it/this (and some variations) (this evening) and report back.
Here are some, preliminary, results.
After some experimentation:
V(tst1) Uncompensated CVS+CCS (left schema)
V(tst2) Compensated CVS+CCS (2nd schema)
V(tst3) Uncompensated CVS+CCS+Shunt (3rd schema)
V(tst4) Compensated CVS+CCS+Shunt (2nd schema)
V(n001) Input voltage.
The V(tst1) track shows some ringing, this may lead to oscillation (especially on a very noisy mains). 1st-ring about 8Mhz 2nd-ring about 4Mhz.
The V(tst2) seems well dampened.
The complete standard Paradise PSU, V(tst3) performs excellent, but one should consider that this is a simulation. Placing real world components on a PCB and connecting an actual power source will have its, negative, influence. The complete compensated Paradise PSU, V(tst4) performs excellent also, the compensation as added in the attached schema, e.g. Cc1=470pF and Cc2=2.7n has no real impact in the functioning of the PSU.
As I’m sure that this is not the final word on compensating (when the PSU oscillates (and if)) we have to wait what kind of results compensation gives on the currently misbehaving PSU’s.
Old 9th January 2013, 05:40 PM   #984
PMA's Avatar
Paradise Builders
OK, now there is a MicroCap and LTSpice simulation result, different simulation software, little bit different excitation voltage and scale of observed voltage plots. To me, based on simulation, the original circuit is only conditionally stable. Now the frequency compensations have to be verified on misbehaving boards.
Old 9th January 2013, 09:11 PM   #985
PMA's Avatar
Paradise Builders
This amplitude and phase response might reveal possible oscillations. Please see circuit without compensation and with 2 compensation capacitors. Caps make the circuit stable, but reduce HF suppression.
Old 10th January 2013, 08:19 AM   #986
Take5 is offline Take5  Germany
DL 103
Originally Posted by Take5 View Post
After some experiments, in my setup 2k works very fine.
After a few hours of listening and more LPs I changed the load resistance to 1k.
Chris
Old 10th January 2013, 08:44 AM   #987
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Paradise Builders
Incredibly good response up to 2M in the first (uncompensated) case.
RC
Old 10th January 2013, 08:46 AM   #988
FdW's Avatar
Paradise Builders
I know/knew
Old 10th January 2013, 08:47 AM   #989
FdW's Avatar
Paradise Builders
Yes that is what I said.
... I did/do prefere option 1 as it preserves the speed of the circuit.
Old 10th January 2013, 08:49 AM   #990
FdW's Avatar
Paradise Builders
That is where the pre-regulator works, it will stop anything in that range (1M and above) before it enters the CVS/CCS/Servo
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1378 Yesterday 10:43 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
