Paradise Builders - Page 97 - diyAudio
Old 9th January 2013, 11:37 AM   #961
analog_sa's Avatar
Some more experiments led to confirming my suspicions that it is the cascaded CCS which is to blame for the 7MHz oscillations. Replaced it with a basic 317/337 based CCS set to 125mA and all is now well.
Not really sure how to cure this. Base stoppers? Would prefer not to dismantle the heatsink but if nothing else works would probably replace the CCS with an Ixys cascode.
Any ideas?
Hesener?
Old 9th January 2013, 11:41 AM   #962
PMA is offline PMA  Europe
PMA's Avatar
Can you post a part of the schematics, with values?
Pavel Macura
http://pmacura.cz/audiopage.html
Old 9th January 2013, 11:47 AM   #963
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Pavel, please go to post 13 Paradise Builders
RC
Old 9th January 2013, 11:53 AM   #964
analog_sa's Avatar
For the convenience of discussion it's below
Old 9th January 2013, 12:13 PM   #965
PMA's Avatar
Analog_sa, this is what I get. I will try to play with caps to compensate those local feedbacks.
Pavel Macura
Old 9th January 2013, 12:22 PM   #966
PMA's Avatar
This is the 1st hint (1n cap in red circle). I am sorry if any of the guys has already suggested this, I was not able to read the whole thread.
Pavel Macura
Old 9th January 2013, 12:28 PM   #967
analog_sa's Avatar
Wow. The simulated waveform is very similar to what i see on the scope. Seems like the simulation predicts something like 4MHz, right?
Old 9th January 2013, 12:32 PM   #968
PMA's Avatar
Yes it does, but I would rather call it indication only. That means, it could be 4MHz or 8MHz or something else depending on real transistor capacitances and PCB parasitic inductances/capacitance. It would be nice if you could try this simple modification and tell if it improves/worsens the situation.
Pavel Macura
Old 9th January 2013, 12:49 PM   #969
analog_sa's Avatar
Just tried it. A bit short of time atm, so didn't do the right thing and use an smd but rather a 750pF polystyrene. Waveform changed a lot and became a lot more complex, while the principal frequency came down substantially. Should have probably tried much larger value caps as well but really pressed for time right now.
Thanks for the help!
Old 9th January 2013, 12:56 PM   #970
FdW is offline FdW  Netherlands
FdW's Avatar
Any ideas?
Hesener?
O.K. (as Hesener said) this is interesting, we/I replaced earlier 317/337 based CCS's with the current CCS due to the fact that (nearly all that where build) of these 317's and 337's oscillated.
There have been numerous builds of the new CVS/CCS combinations and none of them did oscillate, I am real happy that you found out that it oscillates (and not the shunt, the CVS/CCS is easier to compensate and not speed critical (as the shunt)). This will help solve the problem.
It still is not clear to me why some are oscillating, most are not, there must be a reason/different that makes that most do not oscillate.
The most obvious way to stop these oscillations are:
1) Lowering the 330ohm resistors to 50ohm, this makes high Hfe less significant (but this was tried and did not work).
2) Adding compensation capacitors, these should go in parallel to BC of Q104, 204 if the CVS oscillates or/and BC of Q102, 202 if the CCS oscillates (as mentioned by Pavel).
3) [edit] Remove C93 (or replace with an 'low quality'/'high esr' 1u electolitic) (as mentioned by Waly),
@Pavel, good call thanks for that.
I did/do prefere option 1 as it preserves the speed of the circuit.
Paradise phono stage hesener Group Buys 1375 19th September 2016 02:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Copyright 1999-2017 diyAudio
