Paradise Builders
Paradise Builders
Old 8th January 2013, 07:29 PM   #941
Abraxas336 is offline Abraxas336  Europe
Abraxas336's Avatar
Apologies for asking probably stupid quesions but I haven't followed the complete MPP thread. Alfred, you write in the assembly guide "If you want to put the SMD decoupling caps on the bottom side, do that before the heatsink assembly but it doesnt matter much." What does "if you want to" mean - are the SMD caps optional?
Sven
Edit: Nice listening room, Chris.
Gruenschnabel
Old 8th January 2013, 07:29 PM   #942
Take5 is offline Take5  Germany
Sound
Originally Posted by Joachim Gerhard View Post
Cool, tell me more about the sound. This should be encouraging for the other builders.
First, iam not the guy fr big words about sound because in my opinion its a very subjectively thing. Secondly, its difficult for me in english because im not a native speaker, but i will try it:
First impression after powering up was a clear, open sound. After a few hours of listening the paradise sounds clean with a phantastic depiction.The phantom sources of the speakers are exactly represented, so there are many details to hear because there is no overlap or blur effects. Soundstage set back slightly with perfect focus in the middle. In this comparison, for example, loses a pass pearl + ono MC pre.
The tuning of the paradise sounds straight, with no accentuation at any frequency range, very balanced. For some guys perhaps hard stuff, i like it.. But this can be tuned with the RIAA caps.
I hear with a Denon DL 103 in a selfmade zebrano wood body, after searching for five years the perfect cartridge class up 1k Euro its my choise.
Until now I heard with a pre with INA 103 at the first stage , an OP for microphone amplifier, the concept is also DC coupled and sounds well.
The future will show whether the Paradise will replace this Pre, currently I think yes.
Chris
Old 8th January 2013, 07:36 PM   #943
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
Paradise not even boxed and already going strong thanks for the report, and nice setup, very nice player.
Old 8th January 2013, 07:43 PM   #944
Originally Posted by FdW View Post
Paradise not even boxed and already going strong ,
Its time for cases, from 90db up there are microphonic effects
thanks!
Chris
Old 8th January 2013, 08:00 PM   #945
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Nice setup and thanks for the flowers !
Old 8th January 2013, 08:21 PM   #946
dito!
Chris
Old 8th January 2013, 08:30 PM   #947
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Paradise Builders
Hi Chris
Nice TT
What cartridge load resistor do you use with the denon dl103 ?
RC
Old 8th January 2013, 09:22 PM   #948
hesener is offline hesener  Germany
Paradise Builders
Originally Posted by Take5 View Post
Sound
Chris
very nice! this matches many of the betabuilders' impressions of sound (and mine as well). Nice setup!
Still have a DL103 re-tipped, in aluminum body, waiting for its first usage, so after your experience here I will certainly give it a try.....
Old 8th January 2013, 09:24 PM   #949
Paradise Builders
Sven
It doesnt matter much if you put the SMD caps before or after the heatsink, I just find that its a little easier to solder (because the PCB can lie flat - once the heatsink is on there, mounting the caps is a little more complicated). The SMD caps should go on there, quite a few people find that they do not need them but as precautionary measure they should go in, I think.
hope that helps....
Old 8th January 2013, 09:34 PM   #950
Unexpectedly the normal load impedance between 80 - 100 Ohm, used at my other pre, doesnt work. The paradise sounds extremly center weighted.
After some experiments, in my setup 2k works very fine.
@ alfred
DL 103: try also a tracking force of 3 grams, sounds better.
Thank you guys for the flowers.
Chris
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1378 Yesterday 10:43 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
