Old 8th January 2013, 09:55 AM   #931
hesener is offline hesener  Germany
Originally Posted by analog_sa View Post
After running some tests it appears both polarities of the regulator contain some noise around 7-8MHz. Put together a quick 317/337 replacement and it appears all of this is now gone. It's getting late and i hope i am not wrong about this, but so far it looks that at least in my build it was the regulators oscillating.
The offset issue certainly remains.
Interesting..... in the R1 betabuild, we had 4 boards where the regulators (CCS part) was oscillating , and stubbornly so. But these were built around LM317/337 CCS, cascaded with bipolars, and when Frans changed that to the discrete design for R3 that was all gone.....
Old 8th January 2013, 02:47 PM   #932
Bksabath's Avatar
So how s Sheffield then
Old 8th January 2013, 02:56 PM   #933
Marra is offline Marra  United Kingdom
Hesener is there any chance of posting a picture of your input loading and grounding arrangement?Thanks Marra.
Old 8th January 2013, 03:17 PM   #934
Bksabath's Avatar
Sorry to But in Buss of stars on mine
Old 8th January 2013, 03:20 PM   #935
Thanks Bk
Old 8th January 2013, 03:26 PM   #936
Bksabath's Avatar
You welcome
Actually I forgot to put smiley on previous post as picture is upside down
And maybe is worth looking at how the output cables to the Pre-amplifier are arranged
As the Pre amplifier is earthed trough the mains I may be worth cutting the screen at the preamplifier ends and that is why I just sqibled Out on those
By buss of star I mean
Star one all wire to the same point enclosure, board 1, board 2,maybe the ground cable from the arm, this then out to a single cable to the PSU or star 2 as follows: Cable to star 1, ground from pre reg 1,ground from pre reg 2, eart of enclosure and this out to the main plug.
Please note that there are no other earth connection to the cartridge as 4 independent wires are used and that same turntables, Like my RPM4 used to be before surgery, have the screens of the Phono cables connected to earth at the turntable end and this can cause a loop and maybe noise pick up (I say maybe as ground loops issues are a real pain in the bottom.)
Old 8th January 2013, 04:19 PM   #937
Default assembly guide
Hi marra and all,
here the updated assembly guide , check out the last two pages on case layout and grounding. we hope it helps....
Old 8th January 2013, 04:22 PM   #938
Waly is offline Waly  United Kingdom
Originally Posted by PMA View Post
You did not get the point.
Calm down, I guess I did. So, what you posted is a MM amp, not the MC amp you claimed here. Or similar, with a 20dB LT1028 opamp in front. Set aside this flies in your own face (by using a bipolar opamp in front, with the inherent bias current flying in the MC), any comparison with the Paradise falls flat.
BTW, there is much more than "can keep DC output voltage at the value close to Vos voltage of the servo opamp as long as voltage output of the DC servo opamp does not go to saturation" in a servo. I'll let you find out what's happening when the forward and reverse servo loop gains are comparable. BTW, you admit that "For the DC servo is an integrator, it may happen that the whole system's output DC would fluctuate, as it depends on behavior of the circuit that is inside the DC servo loop". At least that, it's a good starting point .
Old 8th January 2013, 04:23 PM   #939
FdW is online now FdW  Netherlands
FdW's Avatar
Originally Posted by hesener View Post
Hi marra and all,
Looks good Alfred
Old 8th January 2013, 07:19 PM   #940
Take5 is offline Take5  Germany
Paradise phono stage hesener Group Buys 1018 3rd May 2013 08:56 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Copyright ©1999-2013 diyAudio
