Paradise Builders Paradise Builders - Page 89 - diyAudio
Paradise Builders
Paradise Builders
Old 7th January 2013, 12:02 PM   #881
hesener is offline hesener  Germany
Paradise Builders
Originally Posted by Take5 View Post
I thing the problem is the common ground of the boards in combination with grounding the input.
Chris
Try a "star" ground at the input connector of the phono preamp, where you take the turntable ground, and isolated metal "bath tubs" for both boards, also connected to the same star ground, that should solve it. You can use double-sided sticky tape to mechanically fix the bath tubs.
Old 7th January 2013, 12:03 PM   #882
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
We added the input offset trim " just in case", to erode even the tiniest amount. A well build Paradise does not need the offset trim and cartridges can be swapped at will.
What happens here is typical. We have discussed this in detail before but for late comers going throw nearly 10,000 posts is hard.
Old 7th January 2013, 12:05 PM   #883
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Paradise Builders
I think we can safely request that people leave their boards powered up fora couple of days before taking any serious measurements from them, then we can eliminate the electrolytic capacitors from the mix. Does that make sense?
Paradise Pre-reg PSU PCBs
Old 7th January 2013, 12:05 PM   #884
The big electrolytics at the emitters of the input transistors lower noise by shunting the AC to ground.
Old 7th January 2013, 12:16 PM   #885
PMA is offline PMA  Europe
PMA's Avatar
Paradise Builders
Originally Posted by hesener View Post
Many (DIY and professional) MC phono pre's are on the market, with DC coupled inputs, and this seems to be a non-issue. In fact, I asked that question over at John Curl's "Blowtorch" thread, and the experts commented that they never saw this as an issue (PMA you may remember as you were one of the experts replying to this).
Hi hesener,
yes I agree with your post. In 2008 I was asked to design a MC preamp. It was completely DC coupled. There was a small-lot production of that phono preamp, like 50 - 100 pcs. None of the preamps produced had problems with DC offset fluctuation, in other words all were stable and output DC offset voltage was like 1 - 2mV or less, depending on ICs used. The preamp was similar to my MM open project with linear 20dB stage added in front of the MM input terminals.
Old 7th January 2013, 12:19 PM   #886
Take5 is offline Take5  Germany
Its more entertaining to hear perfect music with both psu as finding the right grounding with one, but i try it at the evening.
Chris
Old 7th January 2013, 12:22 PM   #887
Paradise Builders
many thanks, thats exactly what we should expect here as well, the remaining offset being the normal offset for a IC opamp without nulling. the proposal from sq225917 makes perfect sense in that context.
Old 7th January 2013, 01:11 PM   #888
dre73 is offline dre73  Netherlands
dre73's Avatar
is there a complete list of the parts?
with order numbers?
Old 7th January 2013, 01:37 PM   #889
Doppelkopf is offline Doppelkopf  Germany
I can increase the LF outputoffsetfluctuation by blowing to the pcb .
The offsetfluctuation is also higher with the 20kOhm on output than without .
I will check to support R15 by a Trimmerpoti when i get one .
The inputoffset is stabil , so the shunt is.
greatings , Dirk
Old 7th January 2013, 01:43 PM   #890
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
I saw your circuit before, but the ground of both boards are common, only the ground of the turntable is decouples through DDRC, right? Chris
Yes you are still I would like you to try it (if posible) (it will/may help other people in the future). Having the DDRC in the player will (IMHO) harm nothing.
Also, the schema as shown makes sure that the -L and -R of the cartridge are separated (all the way) and that the player ground and signal-ground (the arm) are separated (you need one extra wire from the player to the RIAA).
After that all grounds are connected at a 'star'-point in the RIAA-box.
Maybe RCruz has a thing (or two) to add on this subject
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1375 19th September 2016 02:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Copyright 1999-2017 diyAudio
