Old 6th January 2013, 03:53 PM   #851
Joachim Gerhard's Avatar
The Paradise has an input offset trim that reduces DC into the cartridge to minuscule levels. BJTs have a noise advantage under 1kHz because the 1/f corner is much lower then in J-Fets. The 2SJ74 is obsolete so we decided on a BJT input. We could have made a single ended Fet RIAA though or a differential input. Both options give higher noise though then parallel symmetric.
Old 6th January 2013, 04:01 PM   #852
The maximum current that can flow into the cartridge, even without offset trim, is the idle divided by the hfe. The DC ohmic resistance of the cartridge plays a role too. This was discussed in detail before. That can neither destroy nor demagnetize the cartridge.
I have a quite valuable Lyra Titan i and it sounds like on the first day although i abused it with much higher current during my transimpedance input experiments.
We have a Paradise R2 playing since a long time in many systems and on several shows with different cartridges and people are reporting very good results. That Paradise did not have the offset trim. We included it later in the R3 version.
Old 6th January 2013, 04:30 PM   #853
Send a message via MSN to sq225917
Thanks for the detailed explanation Joachim.
hoping to pick up some things.
Old 6th January 2013, 06:14 PM   #854
High hfe in the input stage lowers initial offset. You could also match Ube from NPN to PNP. In the mirrors a hfe of 400 is more then enough.
Old 6th January 2013, 07:08 PM   #855
Bksabath's Avatar
Censored comments about scare mongherers Censored
Built mine R2 with poor matching of transistors and ofset is steady at 0.0+-5 mV (0.05 )
with MC one use cartridge loading say 100 Homs and using formed capacitors helps again
So just get over it.
Ofsett is worth keeping in mind but do not panic over it.
Forming the caps is easy Just get a 317 to suply the nominal voltagge and live the lot there while the boards get populated
Old 6th January 2013, 07:17 PM   #856
Abraxas336's Avatar
What are "formed capacitors"? What is a "317"?
Gruenschnabel
Old 6th January 2013, 07:24 PM   #857
Sandro, is saying that new capacitors take a time to come up to spec and that until that time they will fluctuate and DC will drift.
317 means a simple LM317 regulated power supply.
Old 6th January 2013, 07:35 PM   #858
Originally Posted by hugenh View Post
could one of those in the know (Joachim perhaps) please sum up the latest consensus on optimal hFe?
should i really use the same high hfe throughout the whole board? in the assempby guide input and three other sections are circled in. joachim stated someplace that 400 is enough for the input, but i canot find references to the other sections. there are over a thousand posts in the relevant threads, i`m lost.
ok, thank you joachim. just to confirm: hfe around 500 in the input stage is desirable? any tradeoffs for high hfe there (hbarske stated in one post that hfs >500 provokes instability). in the current mirrors, what is the highest acceptable hfs (have none <480)??
i know, it all depends on a lot of other things, but is there something like a recomendation of optimal hfs-range, provided all pairs are tightly matched?
Ube is between .745-.752 for all devices npn and pnp. thats less than 1%, no need to bother with a closer match?
Old 6th January 2013, 08:49 PM   #859
Waly is offline Waly  United Kingdom
Originally Posted by analog_sa View Post
If i put the wrong wand in the arm a 2k cart may prematurely go to Paradise.
Fearmonger indeed. Not a chance in hell to kill a 2k cartridge with the paradise input bias current. The combination of matched devices and the input bias nulling can bring the cartridge current to well under 1uA (worst case).
In fact, if you connect a 2k cartridge to this preamp, you deserve the "horrible hiss". The noise will indeed be horrible because of the input current noise (wich doesn't cancel as the bias, being from uncorrelated sources). I can estimate the input noise current to about 5pA/rtHz which with your 2k cartridge will give and extra 10nV/rtHz, to add to the 2k impedance noise of 6nV/rtHz plus the 1-2nV/rtHz voltage noise of the preamp. Total is 12nV/rtHz, which is indeed a "horrible hiss" even for a MM 2k cartridge. A decent JFET input opamp like the OPA827 has only 3nV/rtHz typical.
The Paradise should be used only with low impedance MC cartridges. I have to agree, the HF stability of the Paradise is indeed questionable. A small cap (100p or so) connected across the input may cure some stubborn oscillations, a MC cartridge won't care about the cap.
Old 6th January 2013, 08:55 PM   #860
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Hi Wally
I guess analog_sa was writing about a 2keuro cart not 2kohm impedance.
Now your comment about 100p on the input is quite good... would you please elaborate on why to use it ?
RC
Paradise phono stage hesener Group Buys 1018 3rd May 2013 08:56 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Copyright ©1999-2013 diyAudio
