Old 6th January 2013, 12:02 PM   #841
RCruz is offline RCruz  Switzerland
RCruz's Avatar
When you speak about oscilation I guess you mean output offset wondering.... as long as it is on the mV range, I guess it might be due to amplifying noise from first stage.
this build must be enclosed to minimize out put wondering.... once it gets under 10mV there are no audible penalties.
I believe this is the price to pay for high gain dc coupling.
RC
Old 6th January 2013, 12:21 PM   #842
analog_sa's Avatar
None of us are talking merely dc drift here. It is a fast and wild fluctuation, cannot imagine enclosing to have any effect -it's in the hertz region.
Don't know about others but i also see something which may be oscillation in the MHz region. In any case the hiss level is unacceptable and my guess is that it does indeed oscillate.
If i get to play with the board again i would remove all the decoupling lytics from the input stage, then reintroduce them one by one and add decoupling across. Alas, more interesting projects at the moment.
My interest in the issue is mainly academic - i am indeed curious why some builds work only marginally. This can never become my main phono pre due to the input current disbalance. I don't know about others but i have 3 wands for my arm with different carts, ranging widely in impedance. If i put the wrong wand in the arm a 2k cart may prematurely go to Paradise. It is an accident waiting to happen and sooner or later it will. Such a device cannot be sold to a paying customer at any price. Being a diyer does not also make me completely mad.
As for the sound, it is indeed quite pleasant keeping in mind the modest component quality. It certainly does not obliterate my other phono stages soundwise.
Old 6th January 2013, 12:28 PM   #843
buzzforb's Avatar
I would be interested to know what you are comparing it with.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 6th January 2013, 12:37 PM   #844
Send a message via MSN to sq225917
Ananlog_Sa could you outline the cartridge risk due to the current imbalance, I have not seen this mentioned before.
hoping to pick up some things.
Old 6th January 2013, 01:45 PM   #845
Take5 is offline Take5  Germany
Hard words for a non profit DIY project, many people spend there private time. I think you are old enough to decide build it up or not.
I left the DIY scene about for two years and saw the group buy late by random. Thus i read less about the concept only heard a predecessor in 2010 at a DIY festival. But never it was a secret for me about the risk of the design, for example oscillation.
We are DIY people and no plug and play customer, so we should solve the problems together.
To damage the cartridge it needs higher DC at the input. After trimming the input with a dummy, the offset on my board are zero with pluged cartridge.
Chris
Old 6th January 2013, 03:01 PM   #846
PMA is offline PMA  Europe
PMA's Avatar
No current should flow from preamp input into the cartridge coils. In other words, input bias current is not permitted. For this reason, JFETs at the input are much better than BJTs, like in SCP Vendetta Research.
Old 6th January 2013, 03:23 PM   #847
analog_sa's Avatar
True. The problem is that once you change the cartridge to another with a different coil resistance you will have to repeat the offset trimming.
Failing to do this is very unlikely to cause damage to the coils but it will quite possibly cause permanent magnetization - a real pain in the backside. It is even considered a bad idea to measure the coil resistance with an ohmmeter.
Old 6th January 2013, 03:25 PM   #848
Benedetto's Avatar
Right and well, but who told you to do so ?
preregulatorpeterE-MAIL
Old 6th January 2013, 03:32 PM   #849
analog_sa's Avatar
Then you probably had access to information which wasn't public.
Old 6th January 2013, 03:42 PM   #850
analog_sa's Avatar
Huh? A current many times exceeding the ohmmeter's current will pass through the coils if you connect the wrong cartridge. You may still ask who told me to do so, but i and probably many others don't listen to a single cartridge.
Sorry if i am a teeny bit surprised with this design decision. And judging by the posts above not all builders are even aware of such a danger. Maybe two years down the line a third party decides to plug their turntable into this...
Paradise phono stage hesener Group Buys 1018 3rd May 2013 08:56 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Copyright ©1999-2013 diyAudio
