Paradise Builders - Page 77 - diyAudio
Old 3rd January 2013, 09:14 PM   #761
Joachim Gerhard's Avatar
Great Chris, i think you are the first gamma builder that got it working.
Good listening.
Old 3rd January 2013, 09:21 PM   #762
Take5 is offline Take5  Germany
Thank you Gerhard!
Chris
Old 3rd January 2013, 10:04 PM   #763
Nice system that you have.
Old 3rd January 2013, 11:07 PM   #764
Thanks!
In 2008 at the first Frickelfest i presended the system in a older version, in the following two years the setups were made by my friend Heinz and me, i thing you know our setup from 2010 > Frickelfest 2010/DSCN0171
Chris
Old 4th January 2013, 01:13 AM   #765
Yes, i heard that. Not bad at all for a Green Cone.
Old 4th January 2013, 02:21 AM   #766
Banned
Originally Posted by brozatus View Post
Hello,
I am nearly at the point to hook the Paradise to my setup.
I've got everything working, but after having it for 2 hrs.
on the mains I realized the frightening temperature of the
heatsinks.
I can touch them only for seconds.
I run in the regulator with about 29 volts, that should be ok.
But I don't like to burn my house down on accident.
Is there a easy way to get the 29 v a little down to have a
little more headroom regarding the heatsinks?
Thanks,
Christoph
[IMG]Click the image to open in full size.[/IMG]
Either missed my post 726 or ignoring me
Read post 726 answer is there and give you 2 options
Old 4th January 2013, 02:27 AM   #767
Banned
Originally Posted by Take5 View Post
Hello,
today i start up my Paradise. First i started with one supply for both boards, all measurements were fine and so i connect my Denon 103 after set up DC Offset with a dummy.
Big Noise was the first result. Searching the source i found out that both channels playing fine for itself, without pluging the other Channel, it must be a problem with ground.
Second start with two supplies and seperate grounds, lipo batteries from my rc helicopter, and the paradise works fine. So its no question for me to bulid up to supplies.
I was suprised about the sound at the first beginning, fast, open and clear, the perfect match for my DIY setup > Audio » Hörraum
Great job guys! Special thanks to Gerhad for this mad design, i saw and heard one of the first hedgehog at frickelfest 2010
Best regards
Chris
Either missed post 638 or ignoring me
Go and read post 638 answer is there
Old 4th January 2013, 02:38 AM   #768
Banned
Brozatus once you get Paradise working you may find that is worth getting separate box for suply and 2 separate suplies as Take 5 did no need to say one can still ignore me.
So Ignore this as well
From picture you got mains soket right next to caps and Trafo next to cokes and cable running all over the place DC from capacitors running under trafo from looks of it
Move the trafo next to mains plug and rest will slot in to place
FDW on board suply is prety good but......
Old 4th January 2013, 02:45 AM   #769
Banned
DID you lot missed this MY PARADISE
or ignoring me
Old 4th January 2013, 06:49 AM   #770
Dear Bksabath,
at first let me say I never ignored your advices and never will.
As my english lessons at school are now 38 years ago I have some trouble to read and write in english, it is not my native language. So I often have to use Babelfish to translate things. And it is sometimes not so easy to figure out what you meant.
Thanks to your words to my case and cabeling, I will check it again. At least I can manage the arrangement of the dc cables (close to but not under the toroidals).
There are two toroidals and two supplies in the case.
I can easyly built a separate case for the psu, but will try this first.
Best regards,
Christoph
Paradise phono stage hesener Group Buys 1375 19th September 2016 03:20 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 03:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 07:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 05:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 11:19 PM
Copyright ©1999-2017 diyAudio
