Paradise Builders
Paradise Builders
Old 3rd January 2013, 09:05 AM   #751
FdW is offline FdW  Netherlands
FdW's Avatar
Paradise Builders
Originally Posted by brozatus View Post
I can touch them only for seconds.
If you can touch it, then it will be about 80degC, that is acceptable (although a bit high). You can lower the input voltage of the PSU by adding a bit of series resistance to the rectified transformer output, the voltage to the PSU will drop by 1,5V for each 10ohm. In your case you could drop 3V and you should thus use 20ohms (2 * 1.5V = 3Watt will be dissipated by the resistor).
According to Mpp#6462 you could even drop 4.5V = 30Ohm = 4.5Watt
Be sure that air circulates freely around the heatsink.
These are the most important/relevant messages regarding PSU and Pre-Reg.
  1. Mpp #4375 PSU-pre-regulator.
  2. Mpp #4610 V2 Schemas UPS and Amp.
  3. Mpp #6506 CCS fine-tuning.
  4. Mpp #6462 PSU with my notes.
  5. Mpp #6809 Do not try to feed the CVS of the CCS of the shunt with a regulated power supply.
  6. Mpp #7127 More about transformer selection.
  7. Mpp #7635 Single and dual transformer wiring (also corrected drawing).
  8. Mpp #7733 Grounding (PSU, RIAA and Player).
  9. Mpp #7810 35V PSU for the CroMagnon.
  10. Mpp #7830 The PSU explained.
  11. PradiseBuilders #155 Vdc input voltage minimum simulated.
Have a look at these and their following messages.
Old 3rd January 2013, 09:39 AM   #752
brozatus is offline brozatus  Germany
That's perfect!
Thanks a lot, for all the links also.
Best regards,
Christoph
Old 3rd January 2013, 10:31 AM   #753
ste is offline ste  United Kingdom
Many thanks for the links.
Old 3rd January 2013, 11:00 AM   #754
carolus is offline carolus  Belgium
@ FdW,
thanks for the links (& your hints) ... I can see "the trees in the wood" ...
Allez, salukes.
Karel
Old 3rd January 2013, 11:13 AM   #755
Bksabath is offline Bksabath  United Kingdom
Banned
And here is the board lay out for the pre regulator post 4375 as I am currently using with My Paradise R2 I have added further RC stage which can be used to connect cokes
Old 3rd January 2013, 11:58 AM   #756
FdW's Avatar
Paradise Builders
And if you have some spare time, go-to Google.com (yes that one ). In the search-bar type the name of your favorite component (BD140? or (as I did here) LME49710). Then select 'Images' and be amazed . Looking at these images you see odd items (or just interesting ones), select one and have a look.
BTW this is what I found in the LME49710 search results opamp??
Old 3rd January 2013, 04:13 PM   #757
Doppelkopf is offline Doppelkopf  Germany
Originally Posted by Joachim Gerhard View Post
From JP2a to JP2b. Simply from output to ground.
I did it , but it changes nothing on fluctuation .
greatings , Dirk
Old 3rd January 2013, 04:28 PM   #758
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Substitute R15 with a 500 Ohm multiturn trimmer and trim the offset.
Old 3rd January 2013, 07:18 PM   #759
Take5 is offline Take5  Germany
Hello,
today i start up my Paradise. First i started with one supply for both boards, all measurements were fine and so i connect my Denon 103 after set up DC Offset with a dummy.
Big Noise was the first result. Searching the source i found out that both channels playing fine for itself, without pluging the other Channel, it must be a problem with ground.
Second start with two supplies and seperate grounds, lipo batteries from my rc helicopter, and the paradise works fine. So its no question for me to bulid up to supplies.
I was suprised about the sound at the first beginning, fast, open and clear, the perfect match for my DIY setup > Audio » Hörraum
Great job guys! Special thanks to Gerhad for this mad design, i saw and heard one of the first hedgehog at frickelfest 2010
Best regards
Chris
Old 3rd January 2013, 07:40 PM   #760
FdW's Avatar
Paradise Builders
Congratulations, good to see that you succeeded Nice 'Hörraum'.
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1380 10th June 2018 11:18 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
